Old 20th December 2010, 12:07 PM   #1
Default Rowland Consumate Phono amp PSU
Hello folks,
I have a Rowland Research Consummate Phono Amp but without the original amp and PSU.
All I know is the phono amp should be powered by DC +/-22V.
Does anyone has the "pin assignment" of the original PSU output connector as the attached picture.
Many thanks in advance!
Old 20th December 2010, 08:49 PM   #2
Send a message via MSN to sq225917
Open it up, trace the circuit back from one of the pins to the first polarised component you fine, capacitor, diode, silicon chip etc and you will have your answer.
hoping to pick up some things.
Old 21st December 2010, 12:30 PM   #3
Thanks for the tips. I did that already and just found one supply line going into a potted module, so wasn't sure if it's plus or minus.
Jeff Rowland model-9 amp schematic,really? X.G. Solid State 39 10th June 2011 04:15 AM
Need to change phono gain on Rowland phono module Mikelo Solid State 0 4th October 2009 01:43 AM
ROWLAND Research D40 Amp happy_guy Solid State 5 15th September 2007 06:43 PM
PSU for a Gram-amp phono? Regulated or not? Aleksunder Solid State 4 31st July 2007 03:48 PM
Page generated in 0.08389 seconds (70.97% PHP - 29.03% MySQL) with 11 queries
