My 1980's Tangential Tone Arm and my 2010 improvement - Page 2 - diyAudio
Old 8th December 2010, 07:10 AM   #11
Default @ Shaun
Thank you Shaun,
I am quite excited about my 2010 version of this arm. In the next few days I'll post what I have sofar.
Ralf
Old 8th December 2010, 07:13 AM   #12
Default @ Shaun
Hello Shaun,
I'll do that tomorrow when I have daylight available.
Ralf
Old 8th December 2010, 08:53 AM   #13
JRKO's Avatar
Send a message via AIM to JRKO
Default @ Straight Tracker
You really did learn them skilz didn't you?
WOW
Gonna get some metal work fabrication training from an engineer over the next few weeks. Doubt I'll get to where you're at though
If I'm not making noise, I'm making something to make noise
Old 8th December 2010, 08:56 AM   #14
stoN_Cold's Avatar
3x Nice!
Regards zeoN_Rider
Old 10th December 2010, 01:57 AM   #15
theophile's Avatar
I'm replying as a way of keeping track of this thread......
Old 10th December 2010, 03:13 AM   #16
Default Hello theophile
I'll try to keep it interesting.
Sincerely,
Ralf
Old 10th December 2010, 03:16 AM   #17
theophile's Avatar
Sincerely,
Ralf
I promise you,I skip right-over the 'fluff'.
This was interesting from the initial post.Bullseye!
Old 10th December 2010, 03:25 AM   #18
Default Hello Shaun
As you requested, here is a comparison picture of the original prototype and what I call the intermediate version.
The large teardrop shaped base of the original prototype is not really part of the tonearm, rather it is an adapter so that I can mount the tone arm on my oversized Micro Seiki BL91L turntable. As you can see, the overhead track housing is the same on both tone arms. Except that the intermediate version has a transparent cover, so that the special cams and the cam follower can be seen.
Sincerely,
Ralf
Old 10th December 2010, 04:16 AM   #19
Shaun is offline Shaun  South Africa
Shaun's Avatar
Thanks, Ralf. I'm sure this is the most exciting development in vinyl playback systems in recent times.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 10th December 2010, 07:06 AM   #20
Default Hello All,
Now, that I’ve laid the ground work, I am going to post on the new 2010 version of my Tone Arm.
Things are going to progress more slowly from now on because I am building the Tone Arm as we speak, in Real Time, you might say. Of course I would have been done years ago if I hadn’t allowed the appearance of CDs to discourage me.
Over the years I have established certain features that I wanted to be in my Tone Arm:
1) The Tone Arm shall be of the Tangential type that freely pivots on a carriage that is designed to travel in a straight line, which runs through the center line of the platter of the turn table.
2) The pivot for vertical motion shall be level with the top of the LP.
3) This pivot shall not move up or down when VTA/VRA is adjusted.
4) The azimuth adjustment shall be as close to the Tone Arm pivot as possible.
5) The Tone Arm shall not have an offset head shell. ( No skating )
6) The Tone Arm shall freely pivot, to guarantee low horizontal and vertical mass.
7) If possible, the servo mechanism shall be mechanical rather than electronic.
8) At least, the pivots for vertical motion shall consist of “Free Flex Pivots”. http://www.flexpivots.com/swf/single.html
I have used the pivots in item 8) with success in my first prototype. They have no friction, no free play and require no lubrication, Ever. In addition, because these pivots are essentially rotary springs for limited angular rotation they can be used to apply the tracking force to the Tone Arm.
I am attaching three PDF files that show the 2010 version of my Tone Arm in the Rest, Start of play and End of play position. The tracks and the control mechanism have been hidden in the base.
Sincerely,
Ralf
Last edited by Straight Tracker; 10th December 2010 at 07:09 AM. Reason: formatting
Tangential Arm Floating Magnets ebijma Analogue Source 8 6th December 2004 07:37 PM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 08:55 PM
Airpumpless Ladegaard Tangential Arm sreten Analogue Source 31 23rd April 2004 11:58 AM
Turntable physics questions-velocity of tangential arm? perfusionist Analogue Source 66 28th December 2003 05:35 PM
Need tone arm help woody Analogue Source 4 18th June 2003 01:21 AM
Copyright 1999-2017 diyAudio
