My 1980's Tangential Tone Arm and my 2010 improvement
Old 17th December 2010, 06:07 AM   #31
Straight Tracker is offline Straight Tracker  United States
Originally Posted by lowpoke View Post
Almost missed this thread. Very impressive work. I'm tuned in now!
Thank you.
Currently, I'm waiting for some carbon fiber tubing to come from Germany.
Next week I'll probably have some new photos of the latest stand of the 2010 version of my tone arm.
Sincerely,
Ralf
Old 17th December 2010, 09:01 AM   #32
deltavektor is offline deltavektor  South Africa
deltavektor's Avatar
Great work!
"Dont tell me this skies the limit when there is footprints on the moon!"
Old 17th December 2010, 09:09 AM   #33
Originally Posted by deltavektor View Post
Great work!
Thank you.
Sincerely,
Ralf
Old 24th February 2011, 10:09 PM   #34
gninnam is offline gninnam  United Kingdom
Any news??
Old 24th February 2011, 10:17 PM   #35
kevinkr's Avatar
Originally Posted by gninnam View Post
Any news??
I'm interested as well. Intriguing design..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 24th February 2011, 10:44 PM   #36
lowpoke is offline lowpoke  Australia
Any news??
Me too.
Show us what ya got at Homebuilt Hi-fi
Old 25th February 2011, 12:31 AM   #37
Jim Leach is offline Jim Leach  United States
Very interesting design!
When you are ready to go into production (or need a couple prototypes) I have a great machine shop I work with who has VERY competitive pricing.
(I'm currently working on a conventional tonearm that is 14.215" long (effective) to reduce tracking error. I look at your original design because I have looked at older 'similar' ideas and they have been found to be rather difficulr to impliment due to the number of bearings required and the resultant bearing noise/slop/sticktion etc. (I do like those weird rotary spring things however)
From me: BEER=><=YOU
"When the world is running down,
you make the best of what's still around."
Old 25th February 2011, 05:50 AM   #38
popeetheus is offline popeetheus  United States
What an ingenious and elegant design, Ralf. I'd expect that one day soon you might have such an arm for sale in the Music Direct catalog and/or other audiophile outlets.
Your thread here caught my eye as I'm in the process of building a tangential arm, but of the linear track design (servo operated and running on polished rods), roughly based on Rod Cooper's plans in the book "The LP Is Back!".
Old 25th February 2011, 07:01 AM   #39
Default Hello gninnam, kevinkr, lowpoke and Jim Leach
News, you ask? Actually I've been working on the parts almost every day.
I should have some photos next week or certainly the week after that.
My goal is to dynamically balance the arm. I went from brass to copper for the counterweight but couldn't get the center of gravity low enough without interfering with the base of the tone arm. I finally remembered machinable tungsten alloy which has a specific gravity of 18.5 grams per cubic centimeter. It took some time to find a supplier who would sell me a small quantity.
I do the necessary calculations in my CAD program so that I don't actually have to make experimental counterweights.
I did discover something though that everyone else probably already knows:
You can have a counterweight of a given mass 3" behind the tone arm pivot or you can have a counterweight of a greater mass 2" behind the tone arm pivot. the question is: how do you optimize that relationship?
Jim Leach, you're the first one to have discovered my use of "Free Flex Pivots" or weird rotary spring things as you call them.
I'm going to use them in my new Arm also. for both the horizontal and vertical bearings, four in all.
Sincerely,
Ralf
Old 25th February 2011, 07:19 AM   #40
Default Hello popeetheus
Thanks for the kind words.
Hopefully you'll keep us informed as to your progress.
My original Arm was servo controlled. Both my original Arm and my new Arm run on polished 17-4 PH stainless steel rods.
I'm going to try operating my new Arm by the pulling friction between the stylus and the vinyl LP. I know that that will work. The question is: how accurately?
I allowed enough space in the base of my new tone arm to include the components of a servo in case the friction drive is not accurate.
Sincerely,
Ralf
My 1980's Tangential Tone Arm and my 2010 improvementHide this!Advertise here!
Tangential Arm Floating Magnets ebijma Analogue Source 8 6th December 2004 06:37 PM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 07:55 PM
Airpumpless Ladegaard Tangential Arm sreten Analogue Source 31 23rd April 2004 10:58 AM
Turntable physics questions-velocity of tangential arm? perfusionist Analogue Source 66 28th December 2003 04:35 PM
Need tone arm help woody Analogue Source 4 18th June 2003 12:21 AM
Copyright ©1999-2017 diyAudio
