| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Has anyone any ideas on how to build a tube power supply to supply my Origin live dc motor with current. Currently i am using a LT1085 regulator set at 5v with good results. Brinkman makes such a device "Rönt" but i haven´t found much about this device, other than it uses 6BW4, EC360, 6111 tubes. Maybe it exists some even better solution that can make my heavily modified LP12 turntable sound even better.
Thanks, Kenneth Sweden |
#2 |
As much as I love tubes and almost anyone here can attest to that..
What sort of improvement are you looking for? A quieter motor, more torque, better speed stability (IMHO a big problem with many DC motor set ups) or some other aetherial quality you subconsciously (perhaps) perceive your turntable lacks? These are some of the many reasons why I finally went out and bought and restored a Thorens TD-124 based on all of the hype.. Could it be that you have reached the end of the road with this TT? It does happen and perhaps you are ready to move up to something even better.. I have some experience in this matter having progressed through a series of progressively more modified AR-XA tables, to a Thorens TD-166 MKII (not a very bad table but not great either IMHO) to a TD-125 MKI better still, but which never really satisfied, to a rather expensive and unaffordable SME 20/2 which while amazing wasn't quite what I was looking for either although in fairness it was only the acquisition of the very "groovy" TD-124 that made that obvious. Just something to consider... I am going to assume that your current supply is extremely stiff, and has both good short and long term stability. The only improvements you could make are probably to further isolate the motor from the table and damp any vibration it makes. Speed stability issues are something else again, and some have found the OL drives wanting in this department. (I have no direct experience with them, but have extensive experience with very badly designed dc servo-motor based belt drives which failed to please on many fronts.) Hope this is at least a little helpful, and not too negative.
www.kta-hifi.net Last edited by kevinkr; 1st December 2010 at 05:40 PM. |
#3 |
Yes! this was helpful. what i am searching is the best way to obtain speed stability. To my understanding the Origin live dc100 motor i am using of very high quality. Is a positive regulator the way to (LT1085) go? or do i need something more advanced. My Lp12 turntable has a subchassi and frame made of wooden honeycomb, which is imensly stiff. The tonearm is a Rega rb250 with Abec7 ballbearings, the cartridge is a Koetsu black. This setup works just fine.
#4 | |
Perhaps a step up to the DC200 would help address the issue you are having? Another thought would be some sort of active motor regulation based on sensing the motor's back EMF to main constant speed - also compensating for the changing winding resistance as the motor heats up. Are you using their basic controller? They have better ones that presumably do the sorts of things I mentioned previously. Alternately perhaps a good AC synchronous motor would be better? (This is the direction I would tend to go in - I prefer AC motors for their excellent speed stability without servo feedback and sophisticated control electronics.) Sounds like you have done a lot of modification to this table. Lots of fun seeing how far you can take things..
www.kta-hifi.net |
#6 |
No i dont use any of their controlers. I bought the DC100 motor separatly and built my own controler. Thats why i am eager to find out if there are some better way to build a supply that can compensate to some of the limitations i have heard of. I read about some servo circuits that is used with these type of motors.
#7 | |
Edit: I located the original application note from Burr Brown I referenced above: www.focus.ti.com/lit/an/sboa043/sboa043.pdf This will be much better than running open loop. For a more complex design that may perform better check this out: http://electronicdesign.com/article/...-constant.aspx
www.kta-hifi.net Last edited by kevinkr; 1st December 2010 at 07:08 PM. |
#8 |
#9 |
The link to the dc motor controller application note I referred to is actually here: http://focus.ti.com/lit/an/sboa043/sboa043.pdf
To control speed you will need a precision voltage reference and a pot. It would be a good idea to buffer the pot with an op-amp so that varying pot settings do not affect the loop gain of the controller. The math to figure out the control loop is relatively straight forward.. Let me know if you need help with the design side of this.. A bipolar supply is not strictly required but on a single positive supply a negative reference voltage is required so it seems more sensible to just use a simple bipolar supply. I expect +/-9V would be more than sufficient, and the current capability need not be symmetrical.
www.kta-hifi.net Last edited by kevinkr; 1st December 2010 at 10:17 PM. |
#10 |
It wasn't a particularly bad table, but was curiously uninteresting/uninvolving sounding, and not in the sense that I mean it was overly neutral and uncolored, more like blah... Rumble and platter resonances were issues that detracted from the overall performance, the arm is ok, and far worse exist. You've heard the expression: "Damning by faint praise" - I think this applies here, there's nothing terribly wrong per se, it just lacks the kind of resolution, and vanishingly low noise floor I look for. I think though for the sort of money they sell for they represent a good entry point for those just getting into vinyl.. FWIW performance is probably typical of better quality mass market tables from that time frame...
www.kta-hifi.net |
| Turntable Motor Power supply | Jim Leach | Power Supplies | 65 | 26th April 2010 04:39 PM |
| Numark Turntable power supply | plowtan@broward.org | The Lounge | 0 | 28th August 2009 08:12 PM |
| Turntable Power Supply DIY needed | promitheus | Analogue Source | 14 | 21st August 2006 12:02 PM |
| Turntable Power Supply | passing thru | Analogue Source | 3 | 23rd December 2003 09:59 PM |
| Page generated in 0.13393 seconds (84.18% PHP - 15.82% MySQL) with 11 queries |
