Tube power supply for turntable - Page 3 - diyAudio
Old 23rd June 2012, 10:57 PM   #21
Send a message via Skype™ to julienlebas
Thanks Mark. Any recommendations for a fairly simple circuit to control a Maxon 110189 motor? My electronic skills are quite limited and although I received from you and others the article and circuit for your control circuit, I wouldn't mind starting with something a bit simpler. Thanks
Old 24th June 2012, 01:19 PM   #22
The app note circuit Kevin postd is about as simple as possible without huge compromises in performance.
Old 19th July 2012, 10:54 PM   #23
kenneth is offline kenneth  Sweden
Red face Controler
This is the ready built controler. Not yet installed on my turntable, but works fine so far. I will post more pics later when my turntable is ready for a test spin.
Old 20th July 2012, 12:14 PM   #24
Thanks Kenneth for posting these. I am in the process of building it right now. Just one question: did you use an external symmetrical power supply? Or is it part of the board?
Old 20th July 2012, 01:43 PM   #25
Relevant to the title if not the rest of the thread's content, I just found this phot on my hard drive.
It's a PP KT88 power supply for a Garrard 301. I built it about 15 years ago and ran it for a while before going on to other things. Can't remember what happened to it, probably pulled it apart because it was taking up space.
Old 24th July 2012, 06:54 AM   #26
I am using a external +/-24v supply with +/-9v regulators on the board.
Old 24th July 2012, 05:48 PM   #27
Originally Posted by Mark Kelly View Post
Attachment 292367
Puts me in mind of the Valradio Osc / amps that they used to make to drive synchronous capstan motors on tape machines to give variable pitch. four 807s if I remember.
Old 13th August 2012, 02:46 PM   #28
Wink Reference suly
Originally Posted by kevinkr View Post
The voltages I quoted are for the supplies.. You will need a separate reference which could very easily be derived from one of the supplies, I'd recommend an LM385-1.2V reference, a 10T pot for each speed, and a switch to select speed. The LM385 is a shunt reference and can be run off of the 9V supply using a series resistor..
Hello! should the LM385-1.2v reference have a negative (-9v) supply. My controler works but have reversed polarity where the motor is connected.
Thanks, Kenneth
Turntable Motor Power supply Jim Leach Power Supplies 65 26th April 2010 05:39 PM
Numark Turntable power supply plowtan@broward.org The Lounge 0 28th August 2009 09:12 PM
Turntable Power Supply DIY needed promitheus Analogue Source 14 21st August 2006 01:02 PM
Turntable Power Supply passing thru Analogue Source 3 23rd December 2003 10:59 PM
Copyright ©1999-2017 diyAudio
