My latest DIY TT project
Old 28th November 2010, 01:04 PM   #1
Thesoundmen is offline Thesoundmen  Belgium
Default My latest DIY TT project
Hi all,
After reading many logs of people their DIY TT projects, I thought its time to start my own.
The bearing is already in the concept stage and I have a drawing of that to.
The only thing I'm struggling with is what sort of motor AC / DC and what sort of controller.
The platter will weigh 16 kilo or 35,2 lbs.
I have made some 3D drawing in Google SK :
And the bearing :
Comments, suggestions all are welcome.
Old 28th November 2010, 06:17 PM   #2
Greg M is offline Greg M  United States
Greg M's Avatar
Good luck!
I'll be watching, as I am at about the same place as you in making a TT.
Old 29th November 2010, 01:17 PM   #3
Are their any people who can help with the motor problem.
Which is the way to go AC or DC
an what are possible ways of controlling the motor ?
Old 29th November 2010, 01:51 PM   #4
Leon08 is offline Leon08  Germany
Banned
I think the most simple option is to take the motor and controller from some other turntable.
Old 29th November 2010, 02:10 PM   #5
Greg M's Avatar
One method used by amateur astronomers (on their telescope mounts) is to use a synchronous motor controlled by a homemade controller which alters the Hz to correct for tracking errors (when doing astrophotography).
You can find these circuits in back issues of magazines like Sky & Telescope
Just an idea
Old 29th November 2010, 03:59 PM   #6
ReinoutdV is offline ReinoutdV  Netherlands
Default just input for a DIY-TT
Good evening Matthias,
we already had some conversation in Dutch....which is not understandable for all users...so i'll repeat it in short.
I have a serious oversized turntable platter (diameter 50 cm !; 17 kg) and had the same problem as you: the motor.
There are 2 options for this:
- or using a larger motor which is "dominant" over the turntable platter. Logical options are the motors from reel-to-reel tapedecks. Pabst made some really really nice stable motors. These motors have serious torque; they will control the turntable platter with ease. The challenge for this solution is the motor-control. For this you must make a quite complex engine-control.
- or using a quite light motor. Now the turntable platter is "dominant". The motor can be equiped with a rather simple PLL-control and if it runs.....the platter itself is in the lead.
For my TT-platter i opted for the second solution: the light motor. Of course this still has to be a nice stable motor and there are options enough: maxxon, airpax, pabst, premotec ....but i found a funny motor in the former DDR. This is used for tapedecks. It is less then a Watt but it can bring the platter up to speed. This takes time so i help a little...... But when it runs...it runs smoothly/quitly and shockingly stable.
May i suggest to read: krishu.de PLL-Antrieb
My biggest challenge was the building of my own tonearm. A 50 cm platter is fantastic stable (the weigth distribution is far better than a thicker/smaller platter of the same weigth)....but there are very few commercial tonearms available. So i build my own 17.5" arm; and it works like a charm. In the meantime i found ways to improve ths; so i got my Christmas-project already planned.
Back to the motor. Adding a flywheel is totally different. Now you must skip the options for a ligth motor. This will never get a flywheel up to speed which is connected/attached to the platter itself. This means that your stuck to a strong/high torque motor. So you need some serious engine control. If you have the knowledge to do that...fantastic. Remember that making a flywheel contraption is evectively making 2 turntables connected. My suggestion: start with the turntable/motor. If you're not content with the speed stability you can always ad a flywheel later. Again a serious cost driver as the flywheel is the energy reservoir for the turntable platter. So if your platter weighs in at 16 kgs.....
My 17 kgs platter is stable. I have a funny stroboscope and it does 33 1/3 EXACTLY and CONTINIOUSLY. Adding the turntable weigth, stroboscope, vinyl, cartridge.....is simply ignored.....the pll circuit in the small motor simply gives some more and the stroboscope indicates a stable 33 1/3 rpm.
Succes with the building effort. It took me some time and i can only say: well worth the effort !
Greetings from the netherlands,
Reinout
(added some pictures of my contraption. Remember....it is a LP you see...not a small single)
Old 29th November 2010, 04:19 PM   #7
Reinout
Hi Reinout,
Thank you very much for your advice .
I will go with your way without the flywheel it does sound the best option.
I will see how that works out and maybe some time later I make a second motor assembly.
PS : Is that a record clamp with LED ?
Matthias
Old 29th November 2010, 04:44 PM   #8
triocat is offline triocat  England
has your bearing got an oil reservoir?
Old 29th November 2010, 05:10 PM   #9
Yes, but the drawing is not the final design I am working on a new version.
Old 29th November 2010, 06:45 PM   #10
My latest version of the bearing with a Delrin plate inside, also adjusted the size of the ceramic ball.
My latest DIY TT projectHide this!Advertise here!
my latest diy TT project berndt Analogue Source 2 7th August 2009 05:38 PM
DIY TT Project jrevillug Analogue Source 2 15th May 2008 07:35 PM
Which TT do I use as a donor for DIY TT? G Analogue Source 1 13th September 2004 04:43 AM
My DIY TT + Phono amp project penance Analogue Source 3 12th June 2004 10:37 AM
Latest project for one and all Jocko Homo Everything Else 10 30th April 2002 05:02 PM
Copyright ©1999-2017 diyAudio
