My latest DIY TT project
Old 29th November 2010, 07:31 PM   #11
ReinoutdV is offline ReinoutdV  Netherlands
Default Gyrascope
Good evening again Matthias,
you had a question about my stroboscope annex lp-weigth.
I was looking for a way to SEE the rpm's during play. So the normal stroboscope devices do not work (they are UNDER the vinyl that is playing).
Next option is measuring the speed by a sppedometer. It works.....but has a high degree of uncertainty for you must keep your hand seriously steady as this will inflence the measurement.
Then i saw on an audiofair a turntable-weigth annex stroboscope. It is called the Gyrascope and made by the French company Lys.
This battery powered device flashes with the leds (options for 33 1/3 and 45 rpm) and if the rotation is exactly the chosen setting....the leds look like they are not moving. A very nice device: easy to use. Precise.
As the leds will become a nuisance over the time: simply turn the Gyrascope...still in function a a weigth.
I noted that currently there are more of these devices. One is made by Sutherland (Sutherland Timeline). This produces a laser-point on a wall...if it moves....the turntable does not rotate perfectly 33 1/3 or 45 rpm.
The other is spotted on Ebay; it is from the Far East....no more data available.
This answers the quenstion ?
Reinout
Old 29th November 2010, 09:43 PM   #12
Thesoundmen is offline Thesoundmen  Belgium
Reinout
Haha thanks Reinout,
This is something I am certainly going to buy !
For the motor I was looking at Maxon I saw a brush less flat motor there it was a 24V but that not a big issue the fact is you can directly solder to pot meter on the motor to change speed.
Do you now how much torque your has ?
Greetings Matthias
Old 30th November 2010, 12:10 PM   #13
So I made a new design of the motor part.
I have added 2 switches one for the on/off and one for 33/45. Also added 2 pots for fine regulating the speed.
Old 30th November 2010, 07:08 PM   #14
Did some more drawing work on the motor unit this time I worked on the inside of the unit. All necessary cabling comes inside the box except for the PSU than. Everything will be covered with one piece of ALU.
The second photo you can see how the engine is mounted on to the disc.
My latest DIY TT projectHide this!Advertise here!
my latest diy TT project berndt Analogue Source 2 7th August 2009 05:38 PM
DIY TT Project jrevillug Analogue Source 2 15th May 2008 07:35 PM
Which TT do I use as a donor for DIY TT? G Analogue Source 1 13th September 2004 04:43 AM
My DIY TT + Phono amp project penance Analogue Source 3 12th June 2004 10:37 AM
Latest project for one and all Jocko Homo Everything Else 10 30th April 2002 05:02 PM
Copyright ©1999-2017 diyAudio
