A DIY TONEARM - HELP PLEASE
Old 8th December 2010, 11:21 PM   #11
TerryO is offline TerryO  United States
TerryO's Avatar
Originally Posted by Straight Tracker View Post
You might try to attach plumbing fittings to the ends of the tubing. Then pressurize the tubing with a grease gun. Then bend it. Of course the tubing has to be cut a little longer than final size.
Years ago I built a bending machine to bend 7/16" diameter 6061 aluminum tubing into a full 12" diameter circle. I had no problems with doing that because I'd discovered a neat trick, apparently developed by a company called "Tools for bending". It involved a bending wheel with special geometry. If you are truly interrested in that method, I'll make a drawing for you and post it.
Ralf
The idea of packing the subsequently sealed tube with sand or grease is to allow the tube to bend without kinking or having a reduced diameter in the bend. Building custom headers for cars usually involves using a special mandrel that withdraws while the bending wheel is advanced. This requires some precision machine work as the mandrel and bending wheel must be sychronized for a full diameter bend in the pipe.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 27th June 2013, 03:43 AM   #12
Sprags is offline Sprags  United States
Perhaps pouring melted wax into the tube and then letting it harden before bending it into shape will provide enough support to prevent crimping...then heat the tube up until the wax melts and pours or drips out will help?
Old 27th June 2013, 03:47 AM   #13
Luminous is offline Luminous  Australia
here's something you might find useful.. ;-) Prepper Tip- Bending copper tubing with ICE! - YouTube
Old 27th June 2013, 04:19 AM   #14
bullpeters is offline bullpeters  Australia
bullpeters's Avatar
When be ding small diameter copper pipe, for still heat exchangers, u heat briefly to remove temper, put a short strong Spring on the OUTSIDE of the pipe and bend the spring. Only work the metal once or it hardens. I imagine the same process might work for the small s bend in an arm. The spring stops the tube kinking by supporting the tube wall
Old 27th June 2013, 06:28 PM   #15
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
When bending plastic electricial conduit, one put the spring inside the tube....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 28th June 2013, 04:54 AM   #16
hallcon83 is offline hallcon83  United States
Hi , Thanks for the tips - !!! .... I still haven't got to the point of trying the bend yet - I hope to try soon - still sourcing the right tubing.
Kind Regards, Dean
A DIY TONEARM - HELP PLEASEHide this!Advertise here!
Another DIY Tonearm johnmarkp Analogue Source 18 18th May 2008 10:15 PM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
DIY Tonearm kitemap Analogue Source 6 1st December 2007 08:52 PM
