Old 3rd November 2010, 09:53 AM   #1
Default Pacific Riaa
Hi, i've been looking at the threads about the pacific Riaa Phono amp and i would like to build it on a tag strip. I have attached the layout, could someone tell me if it looks correct, and point out any errors for me to correct.
regards
Old 3rd November 2010, 04:13 PM   #2
DF96 is offline DF96  England
Remove the ground trace from the bottom of the 470nF capacitor.
Old 3rd November 2010, 04:22 PM   #3
Thanks for the feedback
regards
Old 3rd November 2010, 05:09 PM   #4
By the way, the LF poles in this RIAA circuit are not particularly accurate. Maybe someone has adjusted it 'by ear' or using an inverse network instead of calculating it properly? Time constants should be 3180:318:75us - I calculate 2438:294:76. This means that bass-mid (below 500Hz) will be boosted by 0.7dB, but will roll off from 65Hz instead of 50Hz. It is not worth using lots of parallel capacitors to make up an exact inaccurate value!
The simplest way to improve it is to change the second gate resistor from 100K to 470K. Alternatively, move the 100K resistor from the second gate to the junction of the 0.47uF and 27K resistor. The first capacitor bank should be 106nF (0.1uF may be close enough), and the second should be 27.7nF (27nF is close enough).
The input resistor ought to be 47K for most MM cartridges.
Old 3rd November 2010, 08:22 PM   #5
Thanks for the info, i will try your suggestions.
regards
Old 4th November 2010, 11:53 AM   #6
Thanks for the help.
Need help with power supply for Pacific RIAA Dmeister Analogue Source 11 10th September 2010 10:58 AM
Hello from the Pacific NW! Brian44 Introductions 4 7th May 2008 08:12 PM
Riaa Pacific Jfet maxpou Analogue Source 23 15th April 2006 05:51 PM
RIAA Pacific deluxe from Elektor peranders Analogue Source 4 26th February 2004 03:52 PM
Pacific Microsonics PMD200? A 8 Parts 2 30th March 2003 02:39 AM
Copyright ©1999-2013 diyAudio
