Magnetic Cartridge Intimacy
Old 1st November 2010, 07:58 PM   #11
imfree707 is offline imfree707  United States
imfree707's Avatar
Send a message via Yahoo to imfree707
Default Loading Included
Originally Posted by sreten View Post
The massive flaw with this approach is that MM's are designed to work
with typical cable capacitance and input loading, in nearly all cases the
response will be far worse than if the buffer is not there, so pointless.
rgds, sreten.
I'll have a standard 47k at the buffer's input and while I'm not sure what optimum capacitance is for the AT92ECD, I'll probably go somewhere between 270 and 470pf, also at the buffer's input. I think the mfgr's allow for 100-200pf cable capacitance and I'll take that into account, too. I'm watching this thread and still comtemplating how to go about this project. I'll be building on a less than 1" X 1" perf board, so the board shouldn't weigh more than a few grams, hopefully allowing total cartridge/buffer weight to still be within limits for the Akai AP-D2's tonearm. Best Regards To All, Edgar
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 1st November 2010, 08:12 PM   #12
R.I.P.
Hi, fair enough, but I cannot see any real advantage over the usual arrangement, rgds, sreten.
(And I can see some noise issues with a less than ideal buffer op-amp.)
Old 1st November 2010, 09:12 PM   #13
imfree707's Avatar
Default Noise Consideration
I'm a bit wary of the potential for noise, myself, and I think noise should be minimal, as the buffer stage will run at unity gain. There is, of course, some noise added to the system by a unity gain stage and one objective of my experiment is to determine if the added noise can be heard, and if audible, do any sonic benefits outweigh the added noise. Advantages are only theoretical at this point, but I expect less hum pick up from tone arm wiring and greater immunity to electrostatic hum pick up by less than perfectly shielded interconnect cable between turntable and amp because of the LM833 buffer's less than 1k output impedance. I'll also be able to "cut n try" various loading capacitance values. Best Regards, Edgar
Old 1st November 2010, 10:28 PM   #14
DF96 is offline DF96  England
You are simply adding noise, weight and complication. The cartridge itself has a low impedance at hum frequencies, so a unity gain buffer won't help there. The cable will already be at least pseudo-balanced so pickup should already be largely cancelled. Capacitive loading is not a problem as the cartridge is designed to require it. All the normal reasons for a local 'head preamp' don't apply. If the problems you are trying to 'solve' really existed then you would not want unity gain anyway, but 10-20dB. People don't even do this for MC cartridges.
Old 2nd November 2010, 12:50 AM   #15
indianajo is offline indianajo  United States
indianajo's Avatar
Default advantages of a headshell amp
Well, there are a lot of reasons why a headshell amp shouldn't be done, perhaps, but turntable to preamp cable length is pretty well fixed maximum 6' or 2m. If I could get 8' or 2.5m, I wouldn't have to walk around three sides of the piano from the record shelf to the turntable, then back around two sides of the piano to adjust the volume after I start the LP. Perhaps there is a better IC and gain than IMfree707 has suggested? A particular FET? rewiring of the turntable arm? Putting a preamp PCBlet in the base of the turntable? I could eliminate the whole disco mixer and use a real $125 PA mixer with tone controls to switch from LP to CD to radio, if the turntable put out 1V PP 600 ohm source. The PAS2 preamp is not at all ideal for 2010, it shorts non-selected inputs, and if you turn the CD player on while the selector knob is on "phono", then it could damage the output stage of the CD player or radio. And a $1000 state of the art Preamp is definitely not happening at my income level. The better half is already griping about the $400 Hammond Organ, the $600 speaker pair, the $200 Peavey amp, the mixer, the graphic equalizer , the digitech . . .
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 2nd November 2010, 12:05 PM   #16
If you can't avoid a very long cable, then put an ordinary RIAA preamp near the turntable and run a long cable to the line stage.
Any well-designed source should include a series resistor in its output so it can be shorted without harm. A few hundred ohms is sufficient for protection, and won't seriously affect cable driving for reasonable domestic lengths.
Old 2nd November 2010, 03:54 PM   #17
kevinkr's Avatar
I agree totally, and having modded a fair number of CD players over the years I have yet to see one that did not have one or more resistors in series with the outputs - besides all modern op-amps are short circuit protected. (This incidentally is also true of all solid state tuners wrt output resistors that I've tinkered with as well.)
FWIW I would take a slightly refreshed PAS-2 over any disco mixer I've encountered any day. (UREI, Peavey, etc.) How about a diy 12B4 line stage or an Aikido - will easily outperform anything you've got on hand.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th November 2010, 07:02 PM   #18
imfree707's Avatar
Default Some Headshell!
I will soon have a turntable and cartridge...snipped text...
Hi Guys, my Akai AP-D2 turntable and AT92ECD Cartridge have been here a few days. The non-removable headshell, while small and having little mass, has "thong" coverage and obviously no space for even my very compact interface board. I didn't even consider using my interface. I built it beforehand, so I may test it, external to the headshell, at a later time. I did design and build my VinyLiberator pre-amp board, as demonstrated in the You Tube Video.
I had absolutely no problem in empirically determining the proper component values for proper RIAA Playback response by simply using my Audio Generator and 'Scope. The 90pf trimmer is quite noisy while being adjusted, but gives a sweet +/- 4db or so "fine tuning" range at 20khz to bring overall response to optimum. I didn't use a cartridge load capacitor because recommended load capacitance was 100pf and is approximately the value provided by tonearm wiring and output interconnect cable. The pre-amp seems only a little noisy and sounds really close to RIAA, as far as I can hear. Thanks, Guys
VinyLiberator You Tube Link
Magnetic Cartridge IntimacyHide this!Advertise here!
Looking for non-magnetic platter Jorgitox Analogue Source 3 7th January 2010 02:14 AM
Tubular magnetic APi Planars & Exotics 6 25th August 2008 04:48 AM
Magnetic shielding jnb Power Supplies 15 9th June 2007 12:12 PM
magnetic Pbassred Solid State 6 26th May 2004 01:14 PM
