The Official Turntable Drive System/Motor Thread! - Page 2 - diyAudio
Old 7th November 2010, 02:20 AM   #11
Default Motors
Back in the seventies I worked as a mechanical designer for Scully Recording instruments in Connecticut. I worked on tape transport design and the preferred Hystersis Synchronous Motors at the time were from Ashland, Bodine, ELINCO ( Electric Indicator Company ) Papst and Beau Motor. They generally had sleeve bearings nearest the capstan for low noise and ball bearings at the far end. I still have a 2-speed ( 600 RPM & 1200 RPM ) Papst motor and a 300 RPM Beau Motor from those days. I bet they would make excellent motors to drive turn tables. Both are so-called
"inside out motors" I'm going to check out the companies I've mentioned
to see if they're still around. I know Papst is. This thread reminded me of
the fact that I still have those motors and it gave me the idea to possibly
design and build my own turn table. That is when I'm done with building
my own tangential tone arm. I'll report if I find out anything about the
companies I've mentioned.
Thanks,
Ralf
Old 7th November 2010, 02:31 AM   #12
Pano is offline Pano  United States
Pano's Avatar
Really? We used a Scully tap deck in the radio station back in the late 70s. Loved it. We used it as our editing deck because of the great transport. Bravo!
And welcome aboard.
Take the Speaker Voltage Test!
Old 7th November 2010, 03:01 AM   #13
Default Thanks
Thanks,
Ralf
Old 7th November 2010, 06:51 AM   #14
Thanks,
Ralf
If you can find a source for these motors newly manufactured, I know several people who want them. I make a driver designed to run this type of motor but it's too expensive for DIY types.
Old 7th November 2010, 01:48 PM   #15
djn is offline djn  United States
djn's Avatar
Hi All, first time posted in this forum. I am building a DIY TT and have a Rek-O-Kut K33 plate with the motor and bearing on the plate. I got the replacement gromets for the motor, but is there anything else I should do to the motor as I move forward?
Old 7th November 2010, 03:25 PM   #16
RIP
pedroskova's Avatar
OK, so this isn't the most sophisticated means for driving a platter, but it works for me. ... Harman Kardon T35C servo-controlled belt drive TT driving the platter/bearing combo from an Immedia RPM-1. I used the HK's pitch control and a stroboscope to dial in the speed. The tape used to drive the platter is a composite of surgical and scotch tape, with the cloth side contacting the platters.
Just need to make it less cosmetically challenged.
Rube Goldberg would be proud.
Old 8th November 2010, 08:25 AM   #17
My current build uses nothing more exotic than a Rega subplatter/bearing assembly and Airpax motor. However, the design allows for easy replacement of both of these by virtue of a simple, easy to replace main subchassis and a separate motor subchassis which has both height and distance adjustment. In addition, the motor subchassis has its own suspension arrangement. I will get this set up working well before I start making any changes.
Old 8th November 2010, 05:55 PM   #18
gtyler is offline gtyler  Canada
How expensive are we talking? I always thought that electrical components were rather cheap, what is the expensive part of it? Is the schematic available?
Old 8th November 2010, 06:22 PM   #19
Jacques Merde's Avatar
Back in the seventies I worked as a mechanical designer for Scully Recording instruments in Connecticut. I worked on tape transport design and the preferred Hystersis Synchronous Motors at the time were from Ashland, Bodine, ELINCO (Electric Indicator Company) Papst and Beau Motor. They generally had sleeve bearings nearest the capstan for low noise and ball bearings at the far end. I still have a 2-speed ( 600 RPM & 1200 RPM ) Papst motor and a 300 RPM Beau Motor from those days.
Hurst was another manufacturer. I don't believe that hysteresis synchronous motors are still in their line.
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 9th November 2010, 10:14 AM   #20
It costs me about $1k to build each one.
Yes, "generic" electronic components are pretty cheap, but you get what you pay for.
Hard drive motor for turntable. TB Analogue Source 12 4th May 2011 10:00 AM
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 5 2nd August 2010 10:19 AM
The official motor regulator circuit lt cdr data Analogue Source 7 2nd October 2005 05:46 AM
servo motor for turntable drive Mikewong Analogue Source 2 18th March 2004 09:51 AM
servo motor for turntable drive Mikewong Analogue Source 3 4th February 2004 10:57 AM
Copyright 1999-2017 diyAudio
