| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I have searched the forum and other sites on the web trying to find the "best" formula for prepairing a solution for record cleaning.
What is commonly used is 3 to 4 parts distilled (or demineralized water), 1 part of isopropyl alcohol and a few drops of wetting agent (like Triton X-100, not Photophlo or Agepon). Somewhere I saw a formula using ethyl instead of isoropyl alcohol. Is there any difference in using either of these two alcohols or it makes no difference? Any comments welcomed. Evangelos |
#2 |
#3 |
Electrons are yellow and more is better!
You can check this thread:
Cleaning my records (HELP!)
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
I have already looked at the links you mention. Thanks.
My main question is whether there is a difference between using isopropyl or ethyl alcohol. |
#5 |
As long as the alcohole is pure I don't think it doesn't matter but in Sweden cannot private persons buy pure 96 or 99.5% alcohole, only T-sprit 96% with womitting stuff.
"Yes" isn't so bad! Watch out for the labels though.
#6 | |
Pure, there is not much difference if used on vinyl. Beware for shellac, I prefer pure water for that. |
#7 |
Also in my country I can easily find pure 95 degrees ethyl alcohol from the super market (although a little expensive - something like 5-6 Euros for a 430 ml bottle).
Anyway, since it makes no difference whether I use ethyl or isopropyl alcohol, I will prepare my solution with whatever is cheaper from those two. Thanks everyone for advise. Evangelos |
#8 | |
Where do you guys find those wetting agents? I have looked around several shops, but draw a blank everywhere. |
#9 |
If you have access to a cleaning device that uses ultrasound, you might want to try that.
I don't know if it works, but those ultrasound baths are supposed to clean very good. If you can find one that's big enough, try it out, and let us know! |
#10 |
[QUOTE]Originally posted by kenev
[B]I have searched the forum and other sites on the web trying to find the "best" formula for prepairing a solution for record cleaning. ----------------------------------------------------- I have tried all sorts including suction devices. I now clean under my shower with light bleach solution to remove mould and nothing else. Alcohol and detergents seem to introduce noise; as does suction in some cases. Use a brush along thre grooves; shower off, wave disc to remove water, pat with soft tissue, then dry under a fan. As good as new in most cases. |
| My Record cleaning machine | edd9000 | Analogue Source | 11 | 22nd March 2009 05:59 AM |
| Cleaning Solutions. | Charged | Everything Else | 10 | 24th April 2007 03:39 PM |
| Record cleaning? | Tazzy | Analogue Source | 4 | 2nd September 2005 01:59 AM |
| Record Cleaning machine | robmorin | Analogue Source | 5 | 28th November 2003 06:48 PM |
| Cleaning airgaps...different solutions? | Netlist | Multi-Way | 4 | 10th October 2003 08:07 AM |
| Page generated in 0.12030 seconds (74.17% PHP - 25.83% MySQL) with 11 queries |
