Old 10th October 2010, 01:32 AM   #1
sled108 is offline sled108  United States
sled108's Avatar
Default Cueing Lift?
I've looked, but have only found lots of Threads on Tonearms. I haven't seen all that much about Cueing Lifts. Sure, I can set a Needle in the Groove by hand, but it is still nice to be able to lift it at the Deadwax and bring it back to it's Rest on a Cue..I have managed to make one that almost works the way that I'd like it to, and I wonder if anyone out there has any good DIY designs for one of these?
Old 10th October 2010, 02:25 AM   #2
sled108's Avatar
This is what I've come up with...It will Lift just fine, but I'm going to the Hardware Store tomorrow to find 2 very light springs to put above and below the Lift Block to hopefully Dampen it a bit.
Old 11th October 2010, 01:43 AM   #3
dtut is offline dtut  United States
Sled,
I've used this design fairly successfully. It's very simple and, as you can see, can be done in wood. For the most recent one, I drilled the outer support to about 7/16" - the lift dowel is 5/16" - leaving a shoulder at the top with a 5/16" hole through it. I put a brad stopper through the lift dowel just above the cam and a spring between the stopper and the bottom of the shoulder. That gave me a positive return and I used plumber's silicone for damping. It was nice and smooth 'til the silicone oozed out. It still works, but not as smoothly.
Doug Tuthill
Old 11th October 2010, 01:48 AM   #4
Tubie Noobie
Thanks dtut. I have seen your design somewhere and was searching for it.
As it is, it would work well, but could easily be improved with brass tubing depending on the skills of the individual.
Living Life Doing the Waltz in 4/4 meter.
Old 11th October 2010, 02:01 AM   #5
SGregory,
The original post was in the "Schroeder arm?" thread - it's deeply buried in there somewhere. The spring loaded version I described was a definite improvement, but I think the next one will be a nylon support and stainless or brass for the lift rod. And I have to find someway to confine the damping fluid.
The hardest part was the 3D positioning and adjusting - making sure it cleared the tonearm at rest, but lifted it well clear of the record, cleared the platter, but could lift the tonearm from the runout grooves - that stuff took forever.
Doug Tuthill
Old 11th October 2010, 12:43 PM   #6
Thats exactly the principal the rega arm lift works on, just made in brass....
Visit www.tirnahifi.org!!
Old 11th October 2010, 01:02 PM   #7
Old 11th October 2010, 04:52 PM   #8
Nanook is offline Nanook  Canada
Nanook's Avatar
Default why dampened?
If care is taken lowering the arm, damning would not be required at all. The thing to consider is how much control one has and how much lift can be had via a cam or wheel
stew -"A sane man in an insane world appears insane."
Old 11th October 2010, 05:02 PM   #9
Tubie Noobie
I thought damning it was an option after one forgot to take care!
A cueing mechanism to buy/DIY theskintman Analogue Source 1 30th June 2008 12:47 PM
Motorized projector lift (scissor lift?) JRace Everything Else 5 7th January 2008 03:11 AM
Cueing mechanism BluesMagoos Analogue Source 0 1st May 2007 07:17 PM
arm lifter/cueing device graeme uk Analogue Source 11 22nd January 2007 05:47 AM
how do I lift/not lift earth frank2395 Pass Labs 30 31st May 2005 07:38 AM
Page generated in 0.10610 seconds (77.60% PHP - 22.40% MySQL) with 11 queries
