| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Tubie Noobie
The time has come to redo my butcherd Ariston Audio RD80. In my youth, I had this great idea of improving the original design and ended up messing it up. Recently I did get it to work quite well when I built the Simplistic JFET RIAA. The problem is that the Simplistic RIAA FAR outclasses the table by many orders of magnitude. Hence, my decision to rebuild it.
My goals for the project are: This is an interim project. I plan to experiment with materials in this build so I can build my Super Table at some point in the future. I want to keep the costs within reason for that reason. Re-use bearing, platter and AC motor. I have the Magnapan tonearm with its slightly off mounting dimension so I would build it for that arm, but yet have the plinth compact enough to play with arms like the Nanook or Schroeder in 12" versions. Size is also important later when I want to externalize the motor. I have decided to forego the suspension and go the route of absorbing materials and mass. An aluminum plate will be sandwiched between instrument grade wood and a cast Silicone / Leadshot composit mass cast underneath. I hope the drawings and picts explain the ideas. The tonearm board isn't shown but will be made of instrument grade curly maple. Despite having no suspension, energy dissapation and absorbtion will be important in the design. The plinth, bearing, and toenarm will each have their own masses which are decoupled from each other. The mass for each will be significant enough to sink the energy. I am very open to ideas, thoughts and experience you may have had building a table. I appreciate all comments both positive and negative in that regard.
Living Life Doing the Waltz in 4/4 meter. |
#2 |
thanks for considering the "Nanook" arm
...it does not belong in the same paragraph as a Schroeder, or similar. My "219" is an easy to make arm using easy to find parts, and I think it competes nicely with my SME 309. I have no idea how it would compare to a a truly excellent design. Think of my "219" as more of an upgraded or modified Altmann tonearm. About as simple as you can get. Your plinth design looks great. The stock Ariston plinths are terrible. On a RD11, they are pressboard veneered with hardwood. I must say that if Linn LP12 tables are similar (never had one apart), then I'd consider them a rip-off. I look forward to your progress.
stew ☮ -"A sane man in an insane world appears insane." |
#3 |
Tubie Noobie
Nanook, your arm is of similar concept to the Magnepan arm I have as well. Simplicity rules if done right so don't humble yourself too much.
I haven't heard either the Shroeder or your arm but I would like to make both. Its cold out so had to take a break from the woodshop. Cutting aluminum with a router is messy.
#4 | |
Hi, considering that you aim for a relatively budget project,you can use a plexiglass tube,for the bearing and platter,circa 120 mm diameter,and a height of 100 mm.It must be "capped",both ends.You can fill the tube with quartz sand or acrylic mastic,though a 50/50 mixture of both,will work wonders,for isolation.You can use some nice cones on the underside,improving immunity from feedback. For the tonearm base,and motor pod use the same technique ,though a smaller tube 80 mm,and the relative height would be fine.You can mount them on a skeletal base,platter and arm,and let the motor pod,be where it fits best. B.L. |
#5 |
Tubie Noobie
B.L. I did think about using sand and still may. I have about 6 liters of castable silicone from a project I had several years ago. It is the stuff that simulates skin and is used by costume designers. It is stable enough not to flow over time but makes wonderfully dead material when mixed with lead shot. I can combine that with a sand pocket to further improve sound absorbtion.
#6 | |
jeff |
#7 |
I was referring to the plinths in particular. The RD11 is very cheap, made of hardboard or similar and veneered. The one I (still) have here is going back the way it is. I've bought some nice teak to make a good plinth. I may re-make the original Ariston using BB ply, and veneer it, just because the stock Ariston one is so terrible, I'd feel bad giving it back to Moray's friend knowing what it is made of.
#8 |
Even the cheap pine plywood from central BC would be a step in the right direction.
jeff |
#9 |
Tubie Noobie
Ok, here is the aluminum sheet for the top plate, now routed out. You can see how the bearing plate, motor mount and tonearm board will be decoupled from each other. The second photo shows the gaps being filled with silicone. The final picture is of the silicone mixed with lead shot.
When I am ready, I will make a mold on the bottom side of the plate to pour each of the masses needed in-situ. They will be seperated by a gap which corresponds to the routed passages. The bearing and tonearm masses will have a cavity for sand as was sugested above.
#10 |
but a couple of thoughts.
Idlers seem to do well with massive plinths, but the consensus is that belt drives sound better on low mass plinths (therefore less stored energy ) or hugely massive ones that basically become energy sinks. Had you considered an ultra lightweight top plate/plinth? Much has been written concerning Linn type tables and light-weight plinths.
| Audio Research amp rebuild | bacoburn | Solid State | 0 | 17th October 2009 10:20 PM |
| Old School Car Audio -- SS D200, Phoenix, etc | Nismoron | Swap Meet | 1 | 30th August 2009 11:18 PM |
| Need suggestions for my next TT - totally lost in the sea of TT models | Razorblade | Analogue Source | 10 | 22nd April 2009 12:28 AM |
| Ariston QDeck TT | jkeny | Analogue Source | 4 | 21st February 2005 07:18 PM |
| DIY tonearm for rebuild tt | Alexander | Analogue Source | 2 | 15th January 2004 08:50 AM |
| Page generated in 0.13334 seconds (79.71% PHP - 20.29% MySQL) with 11 queries |
