| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 | |
My decision to use wood was based on simple practicality. I have an assortment of scrap wood, the basic tools to form it, and it just seemed a good choice at the time. One thing that struck me about this oak unipivot tonearm is how 'quiet' it is, quiet in the sense that tapping it vigorously produces little to no ill effect through stylus/cartridge/amp/speakers. I think oak was a good choice, but it's got me wondering what properties and potential advantages fir, ash, maple, etc.... might offer.
OIIIIIIIO |
#22 |
I believe they make Xylophone blocks with pear wood, so you probably wouldn't want to use that...
#23 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#24 |
Great to see other folks doing unipivots.
cactuscowboy: the arm looks very good, and I am sure it sounds good as well. I do have a minot comment regarding the arm construction. To create a "headshell" that is integral to the arm, it might have been more suitable create a separate "headshell" piece and glue it to the main shaft. The idea there would be to minimize the stress along the grain (I know I'm being anal). Your re-plinth and arm look excellent.
stew ☮ -"A sane man in an insane world appears insane." |
#25 |
Thanks for the comments Nanook.
I hadn't considered "stress along the grain" and I'm not totally clear on the point you're making? If you're referring to physical strength or integrity of the headshell/tonearm there's no worry there as it's very strong. I had considered making tonearm wand and headshell separate, and in hindsight wish I'd gone that direction. As constructed, the offset of the integrated headshell did interfere with working the tonearm wand on the planer and router table. I've been thinking about the next tonearm. I like the idea of continuing with wood, and wonder if a guy could create a wood tube by wrapping/glueing very thin veneer around a round form, say a 3/8" steel rod. Remove the form and you've got a thin-walled and very strong wooden tube. I don't have a wood lathe so that's what got me thinking in this direction.
OIIIIIIIO |
#26 | |
Layers of paper and glue might also be used I suppose, they've built canoes with layers of butcher paper and weldwood glue and they turned out pretty sturdy in actual use. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#27 |
Terry,
Moray suggested this to me about 2 years ago, building an arm with paper (preferably some very nice rice paper or such). If foam filled, it could be a very strong composite arm...
#28 | |
Instead of filling it with foam, how about taking 2 pieces of foam, cutting a groove down the center for your wires, then gluing both halves together and then tapering it. I suppose it might be possible to mount it vertically on a drillpress (poor man's lathe) and gently turn it down. You could then follow it up with paper & glue (or even thinned shellac) as necessary. This is just a idea, you're the expert and you will probably see all kinds of flaws in my mindless imageneering. You know, I might just get off my lazy A** and actually try it when the weather turns cold. ![]() Best Regards, Terry
#29 |
and just because an idea isn't mine doesn't mean it doesn't have merit. I do however like keeping things simple, and I am a little impatient (it would drive me nuts to wait to use the foam/paper arm). Until the arm was in a final state, I'd probably ruin a bunch of them...
The merit of ultra lightweight and self dampened construction has its own appeal, but having an arm too light can create problems as well. The idea of making an arm using foam as a form to wrap whatever kind of material around it, does make sense, but enough material would need to be added until a particular weight is reached.
stew ☮ -"A sane man in an insane world appears insane." Last edited by Nanook; 1st October 2010 at 12:31 AM. Reason: font too large |
#30 |
Interesting ideas!
I've been thinking about the laminated paper or wood veneer tube concept. I like wood from an aesthetic standpoint, but it would have to be very thin flexible veneer resistant to splitting to work. As for a form or mandrel, perhaps a plastic soda straw would be a good non-stick base, with a steel tube to hold its shape while fabricating. Also open to ideas and comments regarding aluminum, brass, carbon fiber, fiberglass, bamboo, types of wood, pros & cons of each, etc...
OIIIIIIIO |
| DIY Golf Club Unipivot Tonearm | cabsvrt | Analogue Source | 31 | 22nd February 2011 12:27 PM |
| diy wooden turntable and phy-hp replica unipivot tonearm | m.corleone | Analogue Source | 36 | 14th August 2010 01:43 PM |
| My unipivot tonearm | wmincy | Analogue Source | 18 | 20th September 2007 05:32 PM |
| DECCA unipivot tonearm | Merijn | Analogue Source | 19 | 3rd February 2003 11:07 AM |
