Restoring and Improving A Thorens TD-124 MKII
Old 10th July 2012, 12:04 PM   #571
missouricatman is offline missouricatman  United States
missouricatman's Avatar
I had a "duh" moment this morning. Earlier I'd remarked that I didn't understand why Thorens would supply a plinth that didn't allow for easy access to the levelers. The answer is they didn't. Grabbed the coffee and headed downstairs to take a closer look. You know, I have this sneaking suspicion that if one were to install a set of new rubber decoupling mushrooms, complete with the metal supports, replacing those that are crushed beyond all recognition, as well as those that went MIA and were replaced by thick rubber washers . . . DUH!
Old 10th July 2012, 04:29 PM   #572
kevinkr's Avatar
Yeah, there were all sorts of aftermarket plinths for the TD-124, some were OK, and some were considerably less so.
The current plinth is useful for the restoration phase, but will not be very good once you start to use the table. The fact that the adjusters physically touch the plinth significantly reduces the isolation the rubber mushrooms were meant to provide. In any event flimsy vintage plinths do not provide the mass or loss required for really silent operation with one of these tables.
I'd recommend a diy CLD type plinth or a more massive slate plinth like the one I use. There are also some decent new plinth options on eBay for the time/skill challenged..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th July 2012, 10:28 PM   #573
Making a good plinth wouldn't be an issue for me. Getting the 2 gram counterweight for the anti skate, now that's proving to be an issue. Joel's package from Germany came today, without the weights! He put it into a standard envelope with a small foam pouch to contain the weights and put it in the mail. I don't know how the weights got lost because I couldn't see a tear in the envelope, but they clearly punched through the foam pouch. Perhaps someone along the way felt they needed to open the thing. Are gram weights contraband somewhere? Whatever. I'm still without the anti skate. drat.
Old 11th July 2012, 04:38 PM   #574
kevinkr's Avatar
Those empty envelopes are a real bummer, I've had this happen too. There are a number of vendors on eBay who sell generic weights for anti-skating set ups and in a variety of different weights. Might want to check that out.
A couple of weeks ago I received a completely flattened AA lithium cell packed in a first class envelope through the mail. Of course they aren't supposed to be shipped that way (didn't know it was coming by mail) but I was pretty impressed - did not keep it in the house fearing it might do something obnoxious.
Old 11th July 2012, 04:57 PM   #575
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Until you source a replacement you can always tie a nut of approx correct weight to a piece of finest fishing nylon and use that...won't look pretty but will work just as well!!
Old 11th July 2012, 04:59 PM   #576
kevinkr's Avatar
This is a great idea in the interim..
Old 11th July 2012, 05:25 PM   #577
Hey, are you guys NUTS? Sorry I just had to say that. Really it would be a good interim solution. Joel's already responded though, saying that he figures it was some of the automatics at the post office that caused the problem. Whatever it was, he said he's got another set and will send those, albeit not in a little envelope this time. I have to say not having seen what he's selling (dumb me) I can't say for certain that they're not generics. He's known to be a good go-to guy for parts so I'm hoping.
Old 11th July 2012, 07:53 PM   #578
Default world's flattest decoupling mushrooms??
OK, I know there is a lot of weight on these things, but seriously . . .
Wonder if the fact the turntable came from THE DESERT had anything to do with this!
Old 11th July 2012, 10:19 PM   #579
brianco's Avatar
The mushrooms I have seen here in the UK all have been GREY in colour....LIGHT grey.
I suspect that these are not makers parts.
I have never seen one perished and suspect that stock mushrooms are some sort of modified rubber. ... but we don't get the temperature extremes which some of you experience.
We always left these out and bolted the TT to a very solid (slate) plinth. Never had FB problems.
Old 11th July 2012, 10:43 PM   #580
Here's a more grayscale accurate photo of one of the mushrooms. While it was purchased north of Phoenix, chances are it spent some time in the Valley Of The Sun. It's quite common for it to be above 115 F. (46 c.) for much of the summer. In a storage locker, well the heat would probably kill you in under an hour!
Restoring and Improving A Thorens TD-124 MKIIHide this!Advertise here!
Need help with Phono Cartridge for Thorens TD-166-MKII sonictonicmusic Analogue Source 20 6th May 2016 07:44 PM
Thorens TD-124 newbie neil_kaye Analogue Source 6 17th March 2008 02:44 AM
Thorens TD-125 MKII Parts needlenose Analogue Source 9 12th March 2005 10:08 PM
Transformer for Thorens TD-166 MKII Peter Menting Analogue Source 5 30th August 2003 06:15 PM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 03:27 AM
