Restoring and Improving A Thorens TD-124 MKII
Old 12th June 2012, 11:19 PM   #551
missouricatman is offline missouricatman  United States
missouricatman's Avatar
Default Newbie with a MK II saying Thanks!
Just a quick note from a newbie here, thanking you all for the detailed information regarding restoration of a Thorens TD-124 MK II. Since I suddenly seem to have one that's functional, serial #63138, with the original motor and second. gen. tonearm, I've got a LOT of reading to do!
Old 12th June 2012, 11:27 PM   #552
kevinkr's Avatar
Welcome to the forum! And welcome to the obsession that is TD-124..
Is yours a very late TD-124 or very early TD-124/II? It's in that near transitional serial number range, but is probably a '124 if I were to guess.
Cream is the 124, gray is the 124/II as a quick way to identify the difference.
What arm is on it, and what sort of plinth is it in? Post pix?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 12th June 2012, 11:36 PM   #553
Hi kevinkr - This is a TD-124/II, gray, with the original motor. I'm learning as I go, but I've read about the "Pabst" motor and clearly I've got the original, not the Pabst.
The plinth is a joke. Apparently someone removed the turntable along with the mounting board, then dropped it into some plinth they just had handy. At least it protected the works until my friend in Arizona spotted it in a thrift store and bought it for me (think the price of a Big Mac).
A few weeks back I was at his place, broke it down for safe transport, and brought it back to Kansas City. I took photos of it as I broke it down, and some more today as I cobbled something together to play one track on it. No more until I get into the motor obviously. Photos coming right up, once I do a little resizing.
Old 12th June 2012, 11:48 PM   #554
Default The "Arizona" TD 124 photos
OK, here's what I know is missing on this find. (1) the arm rest; (2) the anti-skate weight; (3) the rubber bushing for one of the levelers; (4) likely a proper stylus for the un-marked Shure cartridge. I had a spare stylus for one of my Shure MK IIIs that came with a Dual, and as luck would have it, the thing fit, so that let me to a test drive.
Old 14th June 2012, 04:49 PM   #555
kevinkr's Avatar
Hi Missouricatman,
Looks very mint, and will be great when fully restored. The TD-124/II (and 124) were sold sans plinth, and arm, usually with undrilled arm board.
The plinth you have is undoubtedly original and one of the common versions out there. It is not as terrible as you think - but is a candidate for replacement with a nice slate plinth or CLD based plinth. There are a number of plinths sold on eBay that would be a definite upgrade..
The rubber mushrooms under the leveling knobs should be replaced as should the bushings supporting the motor, since you have a TD-124/II you need a kit with six bushings. I specifically would recommend going to Schopper for a replacement belt, the mushrooms and motor bushings.. Jec965 on eBay sells a great motor bearing kit - replacement is easy, just remember to oil impregnate the bearings first.
Use straight 20wt oil for lubrication, what I have found works best so far is Three In One Electric Motor Oil 20 SAE.. (See earlier posts) Look also at the discussion about rebuilding main bearings, and various cautions.. Great bearing.
Be glad you do not have the replacement Papst motor, it is generally inferior in performance to the E50 unless powered by a 3 phase drive such as the Siemens Micromaster MM410 or similar.. (Should be very good with 3 phase drive, may try this some day if I can get my hands on one.)
This is the later Thorens arm, not sure that it ever had anti-skate, but in any event it is nothing special. (Not really bad either) Depending on budget, plinth and other concerns you have eventually want to consider a 12" (sometimes referred to as a 16" arm back in the day) such as the Schick I am using. Vinylengine should have the specifics on your arm. Something like an AT-33 series LOMC should be a good match on this arm, avoid high compliance carts due to the significant arm mass.
Something you probably already know - you have a great friend. He scored you a near exemplary example of the TD-124/II, and as you are probably aware these command pretty high prices on eBay and elsewhere these days. You've got the heart of a first class vinyl playback setup, with some work the performance can be exceptional. I'm am pretty confident based on exposure that my set up can hold its own against some very expensive competition.
Old 14th June 2012, 05:19 PM   #556
Hi kevinkr. Yes, after a little more digging, I discovered the plinth I have is original. Odd that they'd put something out that pretty much makes accessing the adjustable feet impossible. I have some woodworking skills, not to mention a neighbor who's capable of making cabinets, so my guess is we'll be working something out to replace it. Same goes for a plinth for my Dual 1219.
I've seen what Schopper's got as well as Jec965 and agree that's probably the best way to go. This arm does have anti-skate, used a counterweight (I believe two one gram weights) on a nylon string. Everything for the anti-skate is there, just not the string and counterweight, of course. (see attached photo) I pulled the specs on the arm from VinylEngine yesterday. I agree there are much better arms out there, but until I get past issues that keep me from actually putting the turntable into service, it'll do the job. Thanks for all the info.
Old 18th June 2012, 01:45 PM   #557
klinge is offline klinge  Sweden
Default TD 135 Thanks for the help
Thanks for your advices Kevin and Steve. Steve - I got a brake magnet at ebay Germany to a very good price and never had to contact the second person you suggested. I put it in place but to my dissapointment it did not do much difference. So I did as Kevin told me which was to by a new drive belt from Schopper. Pretty expensive but very fast delivery. And Kevin you were quite right I can set the correct speed now.
I have not done anything further to the player and it will probably rest until fall. My plan is to get it in perfect shape during the winter and I guess I will be back to you with some more questions then.
Klinge
Old 19th June 2012, 04:19 PM   #558
kevinkr's Avatar
<snip>
A good, heavy energy absorbing plinth will do wonders for the noise floor of this TT. Mine is in a 4 layer slate plinth and is pretty quiet overall. The mechanism is never silent, but the noise floor is usually dominated by tracing noise and cutter rumble. My last experience with idler drive was not in this league.
Have fun along the way, and there are certainly plenty of good arms out there for the eventual day when you want to upgrade.
I can also confirm that as long as you compensate for the significant magnetic attraction most any MC will work fine with the cast iron platter. (SPU and DL-103D)
Old 19th June 2012, 04:21 PM   #559
kevinkr's Avatar
Klinge
I'm glad that the belt did the trick. I've had quite a lot of issues getting my TD-124s to run at the right speed, mine want to run a bit fast once fully warmed up if not set up just right.
Old 1st July 2012, 03:58 AM   #560
tonepub is offline tonepub  United States
New to this group, and also chasing the rabbit on the TD124. Going to make this an "at it's own pace DIY project....
Serial number is 11,000 something, so guessing I've got a Mk.1
Restoring and Improving A Thorens TD-124 MKIIHide this!Advertise here!
Need help with Phono Cartridge for Thorens TD-166-MKII sonictonicmusic Analogue Source 20 6th May 2016 07:44 PM
Thorens TD-124 newbie neil_kaye Analogue Source 6 17th March 2008 02:44 AM
Thorens TD-125 MKII Parts needlenose Analogue Source 9 12th March 2005 10:08 PM
Transformer for Thorens TD-166 MKII Peter Menting Analogue Source 5 30th August 2003 06:15 PM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 03:27 AM
