Restoring and Improving A Thorens TD-124 MKII
Old 4th October 2010, 05:56 PM   #31
SGregory is offline SGregory  United States
limono,
The leopard wood looks very nice on your TT.
Living Life Doing the Waltz in 4/4 meter.
Old 4th October 2010, 06:00 PM   #32
kevinkr,
There is tons of slate quarries within a couple hours drive of you. Soapstone as well.
I am sure they have drops laying around for a bargain. A simple water saw will cut those in a heartbeat. If you are so vested, Lowes or Home Depot sell an in expensive circular water saw for less than $100. Otherwise look up a local tile installer. Most will cut it for a six pack.
Old 7th October 2010, 01:37 AM   #33
kevinkr's Avatar
Originally Posted by SGregory View Post
kevinkr,
Suggestion is much appreciated, unfortunately I don't have a lot of free time, and my wood working skills while functional are quite rudimentary, and I want this to be very nice in keeping with what I have already invested. The few people I have talked to have quoted me significant money to do the complex cut out in the slate portion for the TD-124 chassis.. I can actually get the whole thing made at a very high level of craftsmanship in Vietnam for a lot less than I could get the comparable item made here, and that includes shipping to get it here. (I have audiophile friends scattered across Asia.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 7th October 2010, 03:24 AM   #34
limono is offline limono  United States
Sounds interesting. If 2 slate plinths would make it more profitable for your friends and the price is accesible I may be interested too if possible :0)
Old 7th October 2010, 09:40 AM   #35
GTHICM is offline GTHICM  United States
Send a message via AIM to GTHICM Restoring and Improving A Thorens TD-124 MKII
Default Slate and Wood Plinths
Limono,
It would be no problem to make an additional plinth for you, if you are interested. Kevin is contemplating one that is extended to take a 12 inch tonearm mounted on the plinth for his TD124.
Old 8th October 2010, 05:31 PM   #36
kevinkr's Avatar
Heard today from the eBay seller of the many rebuild parts I bought for the TD-124, they are all in and the parts will ship this Saturday..
Recent massive multiple computer failures means I have two computers to rebuild before I can start the next phase of the TT project, but I will document and photograph at least some steps along the way once I do get going.
Old 12th October 2010, 11:53 PM   #37
kevinkr's Avatar
The parts have all arrived for the mechanical refresh.. Included are all of the parts needed to overhaul the motor, isolation bushings and a bunch of other parts. Now I just need to find the room to start on this.. Guess that means I should relocate some stuff off of the bench..
I have managed to clear a little space and will start the disassembly, hopefully I can complete the overhaul before the next round of computer parts get here; I will need to focus on that once that happens.
To the right of the picture are the motor parts; felts, bearings, and fasteners, directly below are the special Japanese made motor mounts, and below them is a new Thorens OEM belt sourced from Thakker..
To the left are the TT chassis mounting bushings, again Japanese made, and they may or may not be used in the final iteration - depends on what arm and what plinth I am using..
Note that these parts cost about 3/4 of what I paid for this TT, however once installed the table should perform better than new.. So worth it..
Old 13th October 2010, 02:35 AM   #38
"Note that these parts cost about 3/4 of what I paid for this TT, however once installed the table should perform better than new.. So worth it.. "
I don't think so ..
Old 13th October 2010, 06:24 AM   #39
Default As Good as New?
I don't think so ..
Can we agree on as good as or better than new?
Old 13th October 2010, 07:16 AM   #40
kevinkr's Avatar
Perhaps a bit of hyperbole, OTOH, fresh motor bearings and felts are a lot easier to deal with than cleaning the mess that came out of the motor bearing housings. Green goo - is that what oil turns into as it ages? And quite gluey - some harsh chemicals required.
The gel motor mount bushings are considerably better than the stock or replacement bushings typically available, and they seem to do a pretty good job..
The machine is running on my bench.. It seems reasonably quiet, and should get quieter with some run in time. (The motor got about 4hrs worth)
Obviously I will never know how this machine performed when new as I was not there at the time, the friend whose mother I purchased it from was, unfortunately had nothing more than anecdotal comments.
Better than new is more or less an expression of my enthusiasm.. (Limono this is for you.. ) Get yours sorted out and we can compare notes along the way.. Our journey may not be that different - I have no particular expectations of success, just a lot of hope.
I will say that with the rebuilt motor the speed stability is quite good, and it comes up to speed quickly - this all based on observing the strobe as I have not yet got an arm board and mounted the arm on it. I will say it seems more speed stable than the old TD-125...
I'll post pictures tomorrow evening as I need to go to bed. I took a lot of pictures of it coming apart and going back together. This work with fresh bearings only takes about 6 hrs from start to finish, cleaning and re-oiling bearings will make that about 12hrs I'd guess.
A quick observation, don't overfill the main bearing regardless of web advice - in my case the bearing is so tight that the shaft just sat on the pool of oil and would not fully seat - I had to remove more than half of the oil I added. Also on the MKII at least it seems unnecessary to remove the platter before reinstalling the spindle in the bearing well - just don't force it.
FWIW, the parts to completely overhaul most of this table cost little more than a few minor "spare parts" for an SME 20 with which I am well acquainted, and I also got a reasonably good deal on the purchase of the TT which came with a restorable and now restored SME 3009 Series II. For those who like to tweak this table offers a lot of opportunity.
Restoring and Improving A Thorens TD-124 MKIIHide this!Advertise here!
Need help with Phono Cartridge for Thorens TD-166-MKII sonictonicmusic Analogue Source 20 6th May 2016 08:44 PM
Thorens TD-124 newbie neil_kaye Analogue Source 6 17th March 2008 03:44 AM
Thorens TD-125 MKII Parts needlenose Analogue Source 9 12th March 2005 11:08 PM
Transformer for Thorens TD-166 MKII Peter Menting Analogue Source 5 30th August 2003 07:15 PM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 04:27 AM
