Restoring and Improving A Thorens TD-124 MKII
Old 7th August 2016, 04:48 PM   #2011
missouricatman is offline missouricatman  United States
missouricatman's Avatar
user510 - Steve, just wanted to thank you for pointing out the significance of the switch and bulb holder to achieving proper operation of the motor. It's not something I would have thought of and does beg the question, how many reports of motors lacking torque or not coming to speed at all might be attributable to corrosion in these components. Some accounts, if I recall correctly, may have mentioned test wiring the motor directly, but certainly not all. Your experience suggests even if the motor appears to be operating properly, spending some time on these components is still a good idea. Thanks for the info.
Old 7th August 2016, 05:48 PM   #2012
Arch Stanton is offline Arch Stanton  France
Arch Stanton's Avatar
Beware, these bubble levels are only for fun.
They are not accurate at all, even the genuine one.
To make the level you may take a true level.
Old 8th August 2016, 02:10 AM   #2013
user510 is offline user510
user510's Avatar
Default more switches and bulb holders content
with reference to my previous post re: switches and bulb holders, I took some time to draw a voltage map of the mk 1 scheme. I know there have been a few other maps presented, but I wanted to toss mine into the mix, if Keven allows...
Large file size. This photo is linked from my web page and will remain there so long as I keep paying the bills to my web host.
http://www.theanalogdept.com/images/...tage%20map.jpg
-Steve
Originally Posted by user510 View Post
In recent months I have serviced 4 different td124 units, and each of them presented a unique mix of problems to be solved. But it is the last one that I want to post about today.
The subject is my own td124 serial number 13943. E50 equipped. It has a new coil set from AudioSilente. The motor has received the customary CLA (clean, lube, adjust) and its rotor exhibits very long spin down times while not powered.
The problem was when I put power to it (115 vac @ 60 hz) that the motor exhibited low torque.....not enough to turn the platter.
In trouble shoot mode I first checked to see that the coils were getting adequate voltage. (At the voltage commutator.) I did this with a multi-meter while placing a probe at the red solder tab and the other probe at a black. (both red and black to the same coil) and with power on I read 56 vac. Not enough. I should be seeing full 115 volts. (Btw. Be careful when doing this as accidental electrocution may occur )
Btw, I checked voltage at the mains and did measure 115 vac.
Thinking that the stator coil set should be ok (better than stock) I proceded to search for what was preventing full voltage from getting from the mains to my stator coils. I started with the on/off switch.
To check the switch it occurred to me that what I wanted to know was if the switch, in addition to interrupting the flow of current, was acting like a resistor and not allowing 'all' of the current flow to pass through it. Using the multi-meter again I checked across the switch for ohms. In the past I have measure .1 ohms on switches that were part of a healthy motor circuit. This one was measuring .6 ohms. So I disassembled the switch and cleaned all of the metal parts with acetone. The contact breaker was clean and free of sparking residue, but I washed that with acetone also. Reassembled the switch and conducted the ohms test again. This time I read .1 ohms. Good. That eliminates the switch
But the motor still was not getting 115 into its coils when resting the red and black solder tabs on the commutator. Still 56 vac.
Oh, btw, the neon strobe bulb had been lighting up with apparent strength through out.....and still was. And I had renewed the 33kohms resistor, which measured 33 kohms on the multi-meter.
next, I had to consider if the bulb holder, or the wires themselves were acting as a resistor.
The wires checked ok and looked good. But the bulb holder had an issue I had previously passed over; Of the two spring pins inside that create the circuit to the bulb, one of them had a crunchy action. I could realize this while pressing down on the pin with the eraser end of a wood pencil. Crunchy crunchy. Hmmm. There must be some history there, I thught to myself.
I ohms tested the bulb holder by inserting one multi-meter probe into the hole of the wire clamp and lightly screwed the set screw down to hold that probe in place . Then did same with the second post and probe. With the multi-meter set to measure ohms I placed a flat bladed screw drive across the two pins within the holder to create a short and get an ohms reading. The read was .5 ohms. Hmmmm. Add this to the crunch action of the one pin and it occurred to me that perhaps a little cleaning with acetone might be useful in improving this ohms read.
So I used a modelers paint brush and some clean acetone to dribble some acetone down into the bore and spring of the spring pin. I did this repeatedly while alternately pushing on the pin to work the acetone into the parts within.
You know these bulb holders are not built to be disassembled. The only way to take one apart is to destroy it. Hence my method.
Anyway I continued the acetone with lots of spring pushing to see if I could not clean the conducting surfaces within and get rid of the resistancee I was measuring.
As final touch I dribbled about 3 small globules of light silicone lube into the the pin and worked the action some more with my pencil erasor.
Then, finally, the test...... Multi-meter hooked up as before. This time the reading was .1 ohms. Wow. That's better, let's try it, I said.
Skipping the voltage test at the commutator, I just assembled the wires to the holder and the bulb into it. Assembled the strobe into the chassis as per design and ran the motor.
Guess what....? The motor now had much more torque.! Problem solved?
Well It's running strong now. On a summer morning cool start up I have 33-1/3rd on the strobe within the first rev!
After that, some pitch adjust while all of its drive train parts get up to operating temp...
For future reference my take is to test voltage going into the coil just to see that a switch, a bulb holder, or even a wire isn't acting like a resistor.
-Steve
Old 8th August 2016, 02:15 AM   #2014
user510's Avatar
Appreciated. One thing about testing a motor off the chassis with a direct hook-up is that it avoids using the switch and bulb...so that doesn't take into account these two variables.
It certainly makes the owner feel better when the TD124 is operating at its full potential.....and the motor is such a huge part of this.
-Steve
Old 8th August 2016, 03:01 AM   #2015
kevinkr's Avatar
Steve, with reference to your drawing (let's post it here permanently if OK with you) the black and blue wires where they connect to the socket are the most likely culprit. I usually clean up and sometimes replace the wires if they are too corroded.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 8th August 2016, 03:58 AM   #2016
user510's Avatar
Sure. I'm happy to offer it. I posted the larger drawing because it prints out letter size with decent resolution. A color printer is preferred.
I guess the real thing to inspect is voltage going into the coils. If it is +/- a couple of volts from mains, good. If its quite a bit lower, then it is trouble-shoot mode.
-Steve
Old 8th August 2016, 03:05 PM   #2017
I was talking with a friend who is rebuilding TD 124s, but is not following this thread and mentioned some members were trying to track down a suitable replacement for the strobe bulb holder. He said he'd found one and gave me the link. As I don't recall the rules on direct links to sellers, I'll say it's an eBay seller zappytiger and it's listed as "SATCO Double Contact Bayonet Socket Lamp Holder BA15D Steel Base 120V 500W" Hope that can help someone. He's also found what he believes are equivalent strobe bulbs that are quite inexpensive.
Old 8th August 2016, 08:52 PM   #2018
user510's Avatar
It's an easy google search to find the ebay page with this lamp holder for sale. It is not an exact replacement. It lacks the two posts with set screws that the original lamp holder has. But it's close and could likely be made to work with a little disassembly and soldering, I think.
Yes, there are replacement neon bulbs available. I posted this a couple of years back. This thread is been running long enough that much of its info is buried deep within. The replacements I found I was able to purchase off ebay at around $5.00 each. I recall an ebay seller in Spain was selling this bulb at $20 each. I bought one of those, researched the catalog number printed on the bulb and found the bulbs available off ebay at the $5 dollar price noted above.
-Steve
Old 8th August 2016, 08:59 PM   #2019
Steve he also passed along a page from autoelectricsupplies.co.uk with this one BA15D - PARALLEL PINS. Looks more like what you're describing.
Old 8th August 2016, 09:04 PM   #2020
user510's Avatar
That looks closer. Cool!
I notice the seller seems to specialize in Automotive parts. We need to know if the bulb holder can handle 250 vac as well as the normal 12 vdc used on autos.
Nice info.
-Steve
Restoring and Improving A Thorens TD-124 MKIIHide this!Advertise here!
Need help with Phono Cartridge for Thorens TD-166-MKII sonictonicmusic Analogue Source 20 6th May 2016 07:44 PM
Thorens TD-124 newbie neil_kaye Analogue Source 6 17th March 2008 02:44 AM
Thorens TD-125 MKII Parts needlenose Analogue Source 9 12th March 2005 10:08 PM
Transformer for Thorens TD-166 MKII Peter Menting Analogue Source 5 30th August 2003 06:15 PM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 03:27 AM
