How better is a Turntable compared to a CD?
Closed Thread
Old 8th November 2013, 11:19 PM   #3151
On Hiatus
SY's Avatar
Originally Posted by 45 View Post
Ok. But you need to have corrections to limit jitter which has also different forms. As you have no control on time how can you be sure that you are only removing "the bad and not the good" when it comes to musical signal? I have never found anything satisfactory about this and usually the reasoning stops a simple level relying on the usual hypothesis.
You absolutely have control over the time down to the picosecond level. Merely repeating something incorrect does not make it correct. Likewise, your repeated denial of Shannon-Nyquist does not gather weight with repetition.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th November 2013, 11:27 PM   #3152
45 is offline 45  Italy
45's Avatar
Originally Posted by SY View Post
Quite the opposite, you have exact control of time to the picosecond level. If you're now claiming that Shannon-Nyquist is incorrect, you'll need to do some rigorous analysis to show why generations of engineers are wrong, despite successfully using this very basic piece of mathematics to design CAT scans, MRI, radio telescopes, fighter jets...
Likewise, you seem to be denying the Fourier theorem. You'll need even more rigorous analysis and evidence to convince anyone of that, given a couple of centuries of its successful application.
Interestingly, the page you linked to states all of this as well.
You have control on the sampling rate that is made by clock! I am not claiming the Shannon-Nyquist is wrong don't confuse things. Rather, all those things you citing are not living objects!
In the same way I am not denying the Fourier theorem. It is not valid once you put the listener in the chain. It is valid until the signal leaves the speakers if you have a listener or even after if you have a microphone instead of a human being. It is written in the theorem why.
The audio "science" is so successful that you cannot tell how one thing will sound and you have to listen to it to decide if it is good or not. No such thing as CAT scans, MRI, radio telescopes, fighter jets...I am afraid.
Old 8th November 2013, 11:35 PM   #3153
On Hiatus
SY's Avatar
Yes, and that is accurate to a few dozen picoseconds (a couple of nanoseconds max for mixing boards). You may want to read through the page you linked.
Old 8th November 2013, 11:38 PM   #3154
45's Avatar
I think you have no arguments for my questions!
Old 8th November 2013, 11:39 PM   #3155
45's Avatar
I know what it is says. I read before posting.
Old 8th November 2013, 11:39 PM   #3156
On Hiatus
SY's Avatar
You had no questions that I can see, just a string of incorrect assertions.
Apparently without understanding it, or perhaps missing the key parts.
Old 8th November 2013, 11:41 PM   #3157
jcx is offline jcx  United States
the signal's noise floor creates a "time smear" way above better crystal oscillator sub nanosecond jitter, dithered 16 bit CD may "only" have single digit ns time resolution
the Shannon-Hartley Channel Capacity Theorem applies to analog signals as well as digital - you simply can't get more than BW*SN bits out of any "channel" - including vinyl
and vinyl's potential ~2x higher bandwidth doesn't come close to making up for the higher noise floor
so CD noise floor advantage by itself gives more accurate audio frequency "time" detail than vinyl playback before adding in all of (orders of magnitude larger) phonograph mechanical and time varying geometry arm ,cantilever, stylus contact patch "time smearing" errors
Old 9th November 2013, 12:09 AM   #3158
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
this thread and other threads like these usually go around in circles, so save your energy build something instead, this thread is closed...i will ignore all pm's concerning this thread closure....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Closed Thread
How better is a Turntable compared to a CD?Hide this!Advertise here!
Anyone compared Marantz CD-94 and CD-94MkII? lcsaszar Digital Source 3 6th February 2010 01:56 PM
Pass X 0.2 compared to X.1? output555 Pass Labs 7 7th December 2007 07:59 AM
12AX7 Compared! HiFiNutNut Tubes / Valves 48 29th April 2005 07:07 PM
jh6you compared with other X-eds ljozsef Pass Labs 7 16th December 2003 07:06 AM
Copyright ©1999-2017 diyAudio
