Old 15th September 2010, 11:31 AM   #1
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Thorens motor knocking/tickling noise - solved
well - just found culprit for tickling sound in Thorens motors ;
I made extensive research on net and all I can find are unfortunate attempts in solving that issue
rotor magnet cylinder is filled with two equal plastic cores/bushings ;
but - after many hours of operation - there is slight looseness between plastic cores and magnet and that is reason for magnet "rocking" on cores during revolutions
solution : buy some super glue , and pour some of it on both tops of magnet cylinder - between magnet and shoulders of plastic .
problem solved
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 15th September 2010, 04:00 PM   #2
Zen Mod's Avatar
you must open the motor , drilling points where three stubs are pressed on motor body , and later you must replace them with new ones ( use generic tapped spacers cut to same length) .
whatever you do after removing these tree stubs - use just hands ; you do not need any tool ,and that way you're preventing any damage possibility .
magnet is just pressed on spindle ;
as reminder - there is double metal washer on each side of magnet/shaft combo
dismantle everything and be careful to put magnet back on spindle in same orientation - because of rotating orientation ; anyway - side with shorter center hole part and additional small plastic "ring" is lower -bottom side
clean/wash bearings and shaft with benzin or alcohol
put several drops of super-glue right where I mark with red on attached pic - between ferite and plastic shoulder; glue both sides , off course
wait half hour before motor completing procedure
use graphite grease for shaft/bearings - thin oil is story for little kids , obviously .
Old 19th September 2010, 06:23 PM   #3
kevinkr's Avatar
Which motors specifically does this affect?
Obviously not a TD-124, 121, 224, 135..
I never had this problem with my TD-125 either..
More useful tip if you let people know which motors it affects.
www.kta-hifi.net
Old 19th September 2010, 07:02 PM   #4
Zen Mod's Avatar
all looking like this ( pic from VE ) ;
if I remember correctly - there are both 110Vac and 13Vac ( via controller) versions
Old 19th September 2010, 10:04 PM   #5
kevinkr's Avatar
The motors in TD-125 MKI and MKII are quite different than the motor shown so I can't say whether or not this fix would work in them, OTOH I haven't encountered problems with either version of the TD-125 motors. (Different voltage versions)
www.kta-hifi.net
Thorens TD 160 knocking sound on motor pulley John Wilson Analogue Source 3 6th June 2010 08:05 PM
Thorens motor suspension TerribleT Analogue Source 0 4th August 2008 04:54 AM
Thorens motor runs backwards! GhettoSQ Analogue Source 18 20th September 2006 04:56 AM
Aikido Crackle Hiss Noise Solved dr._sleep Tubes / Valves 1 25th February 2006 12:12 AM
Thorens TD160 knocking sound jives11 Analogue Source 3 24th January 2006 10:58 PM
Page generated in 0.08807 seconds (73.02% PHP - 26.98% MySQL) with 11 queries
