| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Does anyone have a reference for ribbon mics active circuits that don't use transformers ?
The main problem with the ribbon mics is their low output impedance, of about 0.02 ohm, but I think it should be solvable. So, any exiting circuits ? |
#2 |
Nobody knows ?
Another question is this: if an active circuit would replace the transformer that the ribbon mics use for impedance matching, would that be a significant improvement ? I think it might, since the transformers are usually too non linear if one is looking for minimum distortion but I'm looking for other opinions ... |
#3 |
Because of the extremely low output levels and very low source impedance the transformer is almost an ideal step up device translating the large available current into a higher voltage without introducing significant noise. Distortion is easily enough managed. In this case I think the transformer is the best choice from a noise performance standpoint. You may need to shield it to protect against stray magnetic fields, but this may also be a problem with the ribbon itself.
www.kta-hifi.net |
#4 | |
R.I.P.
Without using a transformer - which is against my religion - the noise aspect can be handled by a large parallel arrangement of common base arranged low noise bipolars. Then the current output of the ribbon is fully utilised. A look over the prolific thread MMP here on DIYaudio should give you some ideas to start with. Be aware you can't pass the bipolar's running currents throughthe ribbon, or you will either; 1 damage it or 2/ at least move it out of it's idea position wrt the magnets. Regards, Allen |
#5 | |
#6 |
Hi fireworks,
I've gotten good sound by adapting a low noise moving coil preamp to a ribbon mike. Take a look at Erno Borbely's: "All JFET MM/MC Phone Preamp" part 1 and 2 which includes description, schematic and component values. Google the title for the pdf or visit Borbely website. Borbely's website contains lower noise implementation topologies that Erno sold kits for in the past. All of Erno's articles are a great education. The diyAudio parts forum has seveal suitable JFETs for sale. I found it important to purchase several Id graded JFETs and then also hand match for good performance. I found it necessary to mount the preamp very, very close to the ribbon and to avoid any extra aluminum-copper metal diodes. I built my own ribbons and could run the ribbon foil directly to the JFET input. The diyaudio post by John Curl Blowtorch preamp is a good refresher on low noise techniques. |
#7 |
You will need to parallel a lot of BJTs because of the base spreading resistance. Toshiba has transistors with a specified base spreading resistance of 2 ohms, but that resistance is still 100 times the impedance of the ribbon mike. This base spreading resistance is in series with the ribbon mike and will have a very detrimental effect on the SNR.
Ray |
#8 | |
You would be better off working backwards and computing the output signal for an equivalent SPL and using that number as a target. Once you are down to 10dB SPL noise you have a very quiet mic.
2012, our time is running out. |
#9 | |
I'm quite interested in your ribbon mics: do you have pictures or construction techniques or audio samples ? How noisy are your mics compared to an identical one with a transformer ? |
#10 | |
| DIY ribbon mic | rafafredd | Analogue Source | 6 | 14th September 2009 09:37 AM |
| Coles 4104 Ribbon Lip Mic 4 Sale!! | cempakakuning | Swap Meet | 0 | 10th May 2009 07:39 AM |
| First Watt + transformerless ribbon speaks | george a | Pass Labs | 3 | 25th October 2007 09:52 PM |
| could you make a transformerless short ribbon work with a series Xover | Puggie | Planars & Exotics | 3 | 13th March 2006 12:21 PM |
| transistor circuit to replace transformer in ribbon mic? | ubertar | Instruments and Amps | 1 | 14th August 2004 09:42 AM |
| Page generated in 0.13088 seconds (81.19% PHP - 18.81% MySQL) with 11 queries |
