| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
does anyone have any experience with either of these PSUs and which one would be the best one to go for using either a Systemdek IIX900, Thorens TD160, Rega P2, and which would benefit the most as i have all 3. Mose/ Hercules Power Supply ![]() The Mose/Hercules Power Supply Linn LP12 Brand New on eBay (end time 10-Sep-10 09:28:12 BST) ISOkinetik ISOdrive TURNTABLE POWER SUPPLY ![]() ![]() ISOkinetik ISOdrive TURNTABLE POWER SUPPLY REGA LINN on eBay (end time 06-Sep-10 21:31:23 BST) Thanks :music: |
#2 |
Why don't you ask to see what's in the Isokinetic unit. £10 says it's a transformer, some rectifiers, some caps, and a handful of voltage regulators- nothing you couldn't build.
As opposed to the dual crystal frequency controlled circuit of the Mose- which is a little more, involved, shall we say.
hoping to pick up some things. |
#3 | |
I have found out some more info on the ISOkinetic from ISOdrive ISOKINETIK "The ISOdrive regulates the turntable's motor drive via an intricate quadrature-quartz speed generator, providing unsurpassed speed accuracy and pitch stability. Packed into their hefty shielded steel casework (protecting the units from electromagnetic interference and vibration) are two mains-filtering transformers, and a high-current amplification circuit to assure that the power passed onto your motor is silky-smooth and constant, with no fluctuation and virtually immeasurable distortion." Thanks |
#4 |
Sounds like they are virtually the same then.
#5 |
For the thorens TD160 you should go with the Mose+Hercules II for it cost less than ISOkinetik ISOdrive.I have 2 Mose/Hercules in a TD150 and a TD166mkII they work great and sound great speed is 0.1% +/- of perfect. |
#6 |
+1 for the Hercules PSU. I've installed about half a dozen, and results have been excellent to date.
| Blacksheep Kable AC Power Cord - Hercules Demo | Blacksheepkable | Vendor's Bazaar | 7 | 24th February 2010 07:10 AM |
| Hifonics hercules xi | mike49504 | Car Audio | 12 | 9th January 2010 06:59 PM |
| Hercules PSU for LP12 | richie00boy | Analogue Source | 3 | 9th February 2007 11:09 AM |
| Hercules PSU | bearddavid | Analogue Source | 4 | 14th July 2006 02:28 PM |
| Problems with Hercules Fortissimo III | wigginjs | Digital Source | 2 | 29th January 2005 02:03 PM |
| Page generated in 0.08119 seconds (76.47% PHP - 23.53% MySQL) with 10 queries |
