| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I can find technical measurements for so many things - but almost none for turntables. I'm talking about frequency response, signal to noise, channel separation, nonlinear distortions graphs...
Does anyone have any good sets of data? Occasionally, I can find a little here or there, but nothing really substantial. What are you analog guys scared of???
double complete rainbow all the way!! |
#2 | |
#3 |
wow, flutter, rumble, tracking angle, cartridge overhang, tracking force, antiskate, drag related speed drift, GROUNDING, gain, stylus wear, RIAA EQ, load capacitance.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
I asked the owner of Teres audio for rumble specs on his TTs. His answer was, "It's not about the specs. It's about the music." My translation is: The rumble on his machines is high, or he never tested them in the first place. Totally irresponsible if one is going to sell $10,000 TTs.
Your ears tell you how it sounds, the specs tell you what it DOES.
People in audio whom I admire.... Henry Kloss, Edgar Villchur, John Dahlquist, Bowers and Wilkins, Theil and Small, Don Keele, our own Nelson Pass. In short VISIONARIES. |
#5 |
With the exception of a few (mostly japanese) turntables, the habit of not publishing any technical data became standard. I think the reason for this is mostly that the days of technical competition are over and the few tables that are still out there have found their niches.
If you want to get a (technically) great table, look for 2nd hand direct drives from the 80ies. However, as these sweeties are getting in a tough age, a little experience in electronics for rejuvenation certainly helps. Have fun, Hannes |
#6 |
User account | Vinyl Engine
User account | Vinyl Engine Etc. dig you way through the posts http://www.vinylengine.com/phpBB2/viewforum.php?f=29 rgds,/sreten. |
#7 |
bring back dynamic range |
#8 |
The biggest variation I bet nobody measures is base vibration rejection. Some will skate if you don't tip-toe away on a wood floor. Some will couple the bass of the speaker into the platter and bounce the needle around at normal loud listening levels. Some allow you to dance on a wood floor right in front of it and never miss a note. I have type 3 now, a BIC. My highly rated first generation AR turntable was not nearly as good at rejecting floor vibration.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#9 |
Lots of good input, thanks.
Werner, I did find some interesting info in the archives - like only 20dB channel separation! Seriously?!? I'm kind of amazed at some of it - like the FR variation, and nonlinear distortion performance in some places. If anyone wants to take a look, look at the 2008 archive, particularly articles on cartridges. steten, your links dont work - could you post the titles of the threads, or fix the links? Thanks everyone!
#10 | |
http://www.vinylengine.com/phpBB2/viewtopic.php?t=25622 http://www.vinylengine.com/phpBB2/viewforum.php?f=29 Should work, rgds, sreten. you'll have to sign up to retrieve the pdf's |
| cannabis rex - whos tried them? | freddi | Multi-Way | 0 | 14th March 2010 07:03 PM |
| Whos from nz on DIYAUDIO?? | hasaudio.co.nz | Everything Else | 18 | 27th August 2009 09:17 AM |
| whos knows the most about the TDA1541 ??? | cane2828 | Digital Source | 0 | 7th September 2005 09:17 PM |
| Page generated in 0.11496 seconds (78.08% PHP - 21.92% MySQL) with 10 queries |
