Old 1st August 2010, 07:13 PM   #1
Tubie Noobie
Default Who made this tonearm?
In the attached photo's is my tonearm from years back(at least 20 years). Fresh from its dark and dirty storage in the barn. Unfortunaltley, I lost the box and paper work it came in. I know it is a uni-pivot but for the life of me can't remember the name of the manufacturer.
I also attached a photo of the cable connection and need advise on what to replace the cables with. The newer style cables use the DIN 5.
I will ask forgiveness in advance for letting this thing set in a box and fall into such a state of dis-repair. The stylus is a Talisman S, but with no cantilever.
Living Life Doing the Waltz in 4/4 meter.
Old 1st August 2010, 07:49 PM   #2
fergs1 is offline fergs1  Australia
magnapan unitrac unipivot. Look up vinyl engine in their library section, they will have all you need cheers fergs
Old 1st August 2010, 07:58 PM   #3
Tubie Noobie
Thats it. Thanks.
Old 2nd August 2010, 03:37 PM   #4
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That Magnepan tone arm looks like having very good potential. And its depicted with a Denon in its manual. What is the TT?
Old 2nd August 2010, 04:50 PM   #5
Tubie Noobie
The TT was originally an Ariston Audio RD80. The plinth was flimsy so I built a new one many moons ago out of MDF. Will probably redo at some point after I get the system up and running. As it stands today, I have to rewire it. Will use Cardas Shielded 4x33 in a single run to the RIAA amp for that. I can eliminate the special plug on the head shell and at the base of the arm by rewiring.
I think the photo in the manual shows the DL103D, high compliance version. Back in the day this was a common set up. I am concerned that the arm may not be a good fit for the 130R which is a low compliance cartridge. Will find out soon enough I guess.
Old 2nd August 2010, 06:04 PM   #6
Tubie Noobie
Too late to edit I meant to say DL 103R not DL130R
Old 2nd August 2010, 06:41 PM   #7
sreten is online now sreten  United Kingdom
I'd only consider a very high quality MM for that arm (and on a RD80).
Bang for buck a great MM would wipe the floor re a MC in that arm IMO.
The AT440MLa e.g. :LP Gear: audio-technica AT440MLa AT-440MLa phono cartridge
or on a budget the AT120E/T : LP Gear: audio-technica AT120E/T phono cartridge (retail $159.00)
Or looking for something dirt cheap that could work incredibly well :
https://shop.mantra-audio.co.uk/acat...artridges.html
The rest of my time I'd spend tuning / optimising the turntable / arm.
/Sreten.
Old 2nd August 2010, 07:02 PM   #8
Salas's Avatar
This arm will do about 10Hz Fs with a DL103R. It is 16-16.5 compliance in reality (static 10Hz style) after calculating from the Fs I found on FFT and my arm's mass + 103R.
Old 2nd August 2010, 07:57 PM   #9
Tubie Noobie
sreten, thanks for the input. In general, I have always prefered MC, probably spoiled by the Talisman. I won't be sticking with this table and arm too long as I wish to build my own this year. Maybe when I switch I will put a MM on it and use it as a back-up. Audio Technica are a nice cartridge, I have listened to them in the past.
Salas,
I was thinking about uping the mass of the arm a little when I rewire. One thought I had was to pack the carbon tone arm with talcum. It would dampen it abit while dropping the Fs down a little. I recall 8 Hz being a good number.
Old 2nd August 2010, 08:05 PM   #10
Salas's Avatar
I would not bother. 10-12Hz is further away from warps and eccentricity and I personally prefer it. That arm has a concept. See if it needs any attention, if moving freely etc.
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 10:49 PM
What is this tonearm? IZHAKKATZ Analogue Source 3 23rd July 2007 09:13 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
let me see your tonearm! rbarna Analogue Source 41 16th June 2004 09:25 PM
What to do for a tonearm? DrewP Analogue Source 4 22nd May 2002 05:51 AM
Page generated in 0.10345 seconds (77.96% PHP - 22.04% MySQL) with 11 queries
