| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi, I think the motor on my CJ 55 is dying. I've checked bearings, put on a new belt etc but to no avail. There's monstrous wow now. There always used to be some, but now it is so much worse plus the TT seems to be running slow.
What would be a suitable replacement motor and where could I get one? I think it's a standard synchronous used by many turntables of that era. |
#2 |
Almost impossible to find a drop in replacement.Have you checked the caps and resistors inside the deck?I have the same deck and ended up fitting a DC motor with a shunt DIY supply.
#3 |
Is it not a standard promotec?
| Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted | tiefbassuebertr | Digital Source | 5 | 2nd August 2010 09:19 AM |
| Help required for using a FDD motor as a turntable motor. | binspaul | Analogue Source | 5 | 13th May 2009 03:59 AM |
| Lambda motor vs. XBL^2 motor vs. any other motor | Thinkcat | Subwoofers | 16 | 23rd December 2008 06:23 AM |
| DIY TT: motor, motor PS, platter speed measurements | dice45 | Analogue Source | 52 | 9th May 2006 01:07 PM |
| UK Voltage CJ Walker CJ55 in the USA? | Fingersfrank | Analogue Source | 4 | 5th April 2006 04:55 PM |
| Page generated in 0.06958 seconds (68.28% PHP - 31.72% MySQL) with 10 queries |
