Need help choosing a turntable
Old 26th August 2010, 12:43 AM   #81
kevinkr's Avatar
Originally Posted by vinylkid58 View Post
Massing up the stock arm for cartridges like the DL-103 family is fairly common, so no reason not to try it for other cartridges. The stock C-weight will probably not be enough depending on cartridge weight and added head-shell weight. You'll need to buy/make an auxiliary c-weight. Check out Pat's site:
Technics SL-1200 mods
jeff
You might also consider a used ZU version of the Denon DL-103 which has a 14gm mass by virtue of the aluminum body.. This works a treat in my SME 3009 Series II, however I did have to acquire the supplemental rider weight for the best match. If you are clever you may be able to find another place (closer to the fulcrum) to add mass to the arm that does not compromise tracking as much as hanging it all at the end of the arm.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th August 2010, 02:57 PM   #82
OneyedK is offline OneyedK  Belgium
While listening to my temp solution (see below), I ordered a DL-110 and SL2000 to experiment with.
Had a look at Pat's site but I didn't like most of the solutions :s
The Zu version looks great, but still a bit expensive to my taste, would rather invest in a decent testrecord and some measurement equipment: Adjust+ - Home.
And yes, it should be possible to make a heavier counterweight to replace the original instead of using
and aux weight...
In the meantime I used a temporary fix for the V-15, 10 eurocent weights 4.1g...
Could've done it for half the price, 5 eurocent weights 3.92g, but I checked my clothes and wallet, couldn't find any.
My headshell is a version without a mountig hole for those tiny 2 and 4g weights.
Used a small dot of hot glue instead.
Sounds now exactly like I knew this cart from the Thorens combo...
The Concorde Pro goes back in it's box, don't think it will ever come out again.
btw, while I was at it, measured the capacitance seen by the cart (not connected to amp), only 12pF, that's good, I suppose?!
Old 28th August 2010, 08:00 PM   #83
offwego is offline offwego  United Kingdom
Linn LP2.
If you're not DJ'ing, don't buy a DJ table.
...was given an SP8, which was nice.
Old 5th September 2010, 02:25 AM   #84
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by offwego View Post
Linn LP12
The spastic fantastic.
Oldy belt-driven suspended TT's are fine starters if you're good with alloy/composite chassis building and have resources.
Did that with a 147 in the early 90s, received it as a present, the gift bearer found it in a dumpster.
Blueprinted the bearing to a micron, the platter was balanced on a rig used for car tires.
Nowadays i'm so boring that i got me one with pre-installed xlr outputs (my main junk chain is balanced all the way).
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 5th September 2010, 03:52 AM   #85
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Linn LP12.
I used an Axis for a DJ table once, along with a Planar 3.
LOL!
Yikes! It was THAT FAR out.
jeff
Old 5th September 2010, 11:44 AM   #86
0.1 gram out of wack not good enough, you reckon ?
(would be nice if someone threw an airblown Indian Sig in the dumpster, not that i'd be abled to haul it into the house)
Old 12th September 2010, 05:41 PM   #87
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Choose from ProJect product line.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Need help choosing a turntableHide this!Advertise here!
Help required for choosing an AC sync motor for a belt driven turntable. binspaul Analogue Source 58 20th May 2010 05:38 PM
Choosing a amplifier - What's in a name? Flyin11 Car Audio 11 28th October 2007 07:35 AM
help on choosing insulator rebojorge Pass Labs 4 4th March 2005 07:26 AM
Need help choosing a amp Dysturbed_90dx_ Car Audio 5 22nd May 2004 10:53 AM
Help with choosing tweeter Mos Fetish Multi-Way 11 18th July 2003 03:01 AM
Copyright ©1999-2017 diyAudio
