| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Recently started using a old Linn LK-1 preamp - amongst a number of design features that are either interesting or bizarre -( your choice) both MC and MM inputs are capacitor coupled - why'd they configure it that way ?
Amongst other things - this would seem to make loading down MM carts by simply using the y-plug and parallel resistor technique ineffective ? |
#2 |
diyAudio Chief Moderator
They use BJT head amp probably and maybe there is significant input offset danger in their design (especially for production run, not lab matched and trimmed input section parameters) to create enough current through the carts. AC loading impedance remains unaffected.
#3 |
If I understand this correctly (which implies I understand it at all -clearly not the case)- then adding 47kOhm via external Y-plug across the existing 47kOhm MM section will still yield 23.5 kOhm - the input coupling cap won't make any difference in this ?
#4 |
Will only remain 47K for DC and it will halve for AC. Music is AC. But I would do that inside, soldering the extra resistor on top of the original load resistor for quality reasons anyway. The distance's inductance for the resistor combo will make Y a poor & subjectively misleading choice.
P.S. Have a check it is 47k internally and not 100k, because I just saw a 1989 review that Stereophile's Atkinson had found 100k for MM, 220R for MC and 100k for line despite the published specs. He also confirms it is BJT input with an LM358 DC servo around a cascode dif head amp with tantalum(!) input caps most likely for MC, but thankfully polycarbonate for MM in your case. |
| Balanced input all DC coupled RIAA preamp | FdW | Analogue Source | 82 | 5th February 2012 06:22 PM |
| 6T9 push pull with Cathode Coupled input | Brit01 | Tubes / Valves | 5 | 18th January 2009 11:58 AM |
| Transparent, Non-Microphonic Input Cap for Phono Preamp? | thermionic | Solid State | 7 | 31st July 2008 09:17 PM |
| Simple Cap-Coupled CF Advise Needed | dr._sleep | Tubes / Valves | 6 | 10th August 2005 06:50 PM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.08679 seconds (71.34% PHP - 28.66% MySQL) with 10 queries |
