| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 | |
The reset board is an option, so the schematic is okay. I just shorted the reset switch (center of the pot switch) so the turntable circuit thinks that the speed should be locked to the 0 pitch and it worked. Now I need to see if it stays working or if there really is another problem lurking in the control board. Thanks! |
#12 |
I don't know how well the strobe dots are supposed to stay fixed, but there is a tiny amount of wobble from time to time. It is very slight, but visually detectable.
#13 |
After spinning a few LPs it appears that the turn table is working. Thanks, all, for the help!
#14 | |
Can you send me the service manual for the 1200? Thanks, Aaron jaaron5@hotmail.com |
#15 |
I would check the power supply first. The regulator and it's solder connections could be flaky. If voltages are stable next check the quartz crystal oscillator and verify motor connections. It is unusual for crystals to intermit or change value; so see if you can check all other components in the speed control loop.
The external speed control fader should be bypassed when pitch control is off so should have no effect. The internal trim pot is used to set the reference speed and can visually be verified by the strobe. If speed is still changing, suspect an open in the motor speed control loop. Please post your findings. Generic parts can hopefully be found to replace what has failed. Packaging may be different and may require adaptation to fit. |
| Technics Sl 1200 bearing | nimbus24 | Analogue Source | 10 | 22nd July 2009 11:27 AM |
| only right sound from my Technics SL-1200 | kollisionseb | Analogue Source | 3 | 12th February 2009 10:59 AM |
| Technics SL-P 1200 | NoBit | Digital Source | 0 | 18th April 2008 11:28 AM |
| technics SL 1200 MK3D tonearms | flip | Analogue Source | 4 | 6th September 2007 01:43 PM |
| Technics SL-1200 Mk2 pitch control | Clark2000 | Analogue Source | 18 | 13th August 2003 06:00 PM |
