MY TT build
MY TT build
Old 8th June 2010, 10:18 PM   #1
3GGG is offline 3GGG  Australia
Default MY TT build
Hi All
Thought i would post some pics of my TT build.
The base is 80mm South Australian slate. The platter is 75mm acrylic i got spun up at a near by engineers shop, $$$$!
The bearing is a teres bearing and tone arm is origin live, fully modded.
Ill post some details on the AC sync motor control later.
Now waiting on another piece of slate to house motor and speed control.
Old 9th June 2010, 05:02 PM   #2
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 MY TT build
Nice work, buy some dusters... ;-)
Paradise Pre-reg PSU PCBs
Old 9th June 2010, 08:35 PM   #3
moray james is offline moray james  Canada
Beautiful! Thanks for posting pictures of your inspiring work.
moray james
Old 9th June 2010, 10:04 PM   #4
eldarvanyar is offline eldarvanyar  United Kingdom
Stunning Turntable, where did you get the acrylic platter from and the motor etc?
Old 10th June 2010, 12:11 AM   #5
Thanks for the kind words. It is alond way off the final dusting and polish
The acrylic was purchased as a block then custom machined. The engineer shop spent 6 hours machining and polishing. The guy was great to deal with and gave me a good price considering the work envolved.
The slate is from Mintaro slate in South Australia. Nice quality stone with no defects in it. Motor is an AC sync motor from ebay. Ill posy some pics of the speed control when its finally built. It is going to be housed in a seperate stone housing that sits neatly along side the TT. My brother is an elec engineer and has programmed some chip to produce the two offset frequencies. Then i used two LM 3886 boards from chipamp.com to amplify the signal. With rthe push of a button i can adjust frequencuy and voltage. Sorry i dont know the fine details, all this DIy electrical is newto me.
Old 10th June 2010, 12:18 PM   #6
cjcc67 is offline cjcc67  Australia
nice work you must be happy with it
Old 10th June 2010, 03:35 PM   #7
prestonchipfryer is offline prestonchipfryer  United Kingdom
prestonchipfryer's Avatar
A truly magnificent piece of work, well done
Old 15th June 2010, 05:29 PM   #8
kach22i is offline kach22i  United States
kach22i's Avatar
Nice table you built.
I did not know that you could still get the bearing from Teres.
Tubes and Martin Logan's
Old 15th June 2010, 10:09 PM   #9
I know they have stopped producing them and what is left is all there will be.
Old 22nd September 2010, 12:33 PM   #10
The TT is pretty much complete. I just need to finalised the wheel for the motor.
The platter spins beautifully with either a fine thread of cotton or with the rim drive using an O-ring. unfortunately it will be a little while until i can do a comparison. Whensetting it up for the first time I managed to brush my hand against the DL103R and snap the entire stylus off!!
The speed control works beautifully and is housed below the motor on the slate motor/speed control housing. The platter get up to full speed within a few seconds, then reduces its voltage output for a smooth ride.
I need to get a hurry on with the HPS 5.1, then maybe some horn speakers
MY TT buildHide this!Advertise here!
Looking for TT help Francop23 Analogue Source 9 17th February 2010 07:35 PM
Need suggestions for my next TT - totally lost in the sea of TT models Razorblade Analogue Source 10 22nd April 2009 12:28 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Which TT do I use as a donor for DIY TT? G Analogue Source 1 13th September 2004 04:43 AM
