| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
First, you need to verify the AC voltage that goes to the motor. It usually is 110V(120V) @ 60Hz here in North America. But the Thorens may step it down with a transformer.
Once you verify the voltage, you can calculate the speed in RPM. V=(120Xf)/n V is RPM f is frequency of the voltage feeding the motor n is the number of poles in the motor so if f is 60Hz, and n=16, then the motor speed is 450 RPM Several Ac motors are available to run 300 RPM@60Hz. You may just need a suitable motor pulley that is 50% larger. Eg: if the original pulley is 20mm in diameter, then a new pulley would need to be 30mm in diameter. (original RPM/original pulley diameter)=(new RPM/new pulley diameter) and solve for the new pulley diameter.
stew ☮ -"A sane man in an insane world appears insane." |
#12 |
Thanks for the formulas, Nanook. Interesting stuff, though I doubt I'd be able to fabricate a pulley.
#13 |
Keep an eye on eBay TD-160 motors show up pretty frequently..
Synchronous Motor Speed equation: V= (2F x 60)/N Where: 60 is the number of seconds in a minute (duh!) V= output rpm F = line frequency 50/60 Hz or any other value such as that provided by an AC electronic speed control (TD-125, etc) N= number of poles Voltage is not required. Gives the same result as Nanook's equation
"Extraordinary claims require extraordinary evidence." - Carl Sagan Last edited by kevinkr; 30th June 2010 at 05:10 PM. |
#14 |
Hello! I am a new member. I see you said you have a td 160 out of use. I need a motor pulley for this turntable. Are you interested in selling the motor pulley of your turntable? If not, could you please inform the dimensions of the pulley, so that I can manufature one to replace in my turntable? Thanks a lot!
Derek Dick |
#15 |
Hi, I'm new to the forum and looking for advice.
I'm looking at replacing a shaft on a TD 160 motor. I'm on a tight budget, so I'd rather not buy a new one as they appear to be quite sought after. The shaft has snapped and I have access to a machine shop where a new one could be made and pressed. Has anyone ever tried this? Is the shaft knurled or splined, or just a straight press? Could it be precision drilled out if pressing isnt an option? Also, would anyone have drawings or dimensions for the pulley assembly? Is it with clutch or fixed to the shaft? Any advice would be greatly appreciated. Thanks |
#16 |
I have a good original motor with shaft available....
#17 |
is this a 50hz motor/pulley? how much would you like for it?
| Thorens TD 160 knocking sound on motor pulley | John Wilson | Analogue Source | 3 | 6th June 2010 08:05 PM |
| Thorens TD 160 Super - anybody else use one? | Gretsch6136 | Analogue Source | 23 | 6th June 2009 04:26 AM |
| My own TD-160 Plinth Story | GhettoSQ | Analogue Source | 2 | 11th February 2007 10:09 PM |
| thorens td 160 replacement motor | dionysio | Analogue Source | 2 | 31st March 2004 03:45 AM |
| Thorens TD-160 Replacement Motor | dzeetz | Analogue Source | 9 | 15th January 2004 07:58 PM |
