Hps 5.1
Hps 5.1
Old 6th May 2013, 12:28 PM   #171
rsavas is offline rsavas  Canada
Hello folks,
Is it possible to post the BOM. A Digi-Key or Mouser packing list in .pdf would suffice for me.
Thx Rick
Old 8th May 2013, 10:20 AM   #172
PixelPlay is offline PixelPlay  Australia
Well I found the problem, one dry solder joint on a cap and a bad phono cable. It's back up and running. Just goes to show that the diodes actually do protect the ps! Man I'm really impressed, I'm spinning some old Bauhaus for a change and don't feel like moving off the couch. I still have to decide on the 6.8uf output caps, as I have some generic polypropylenes in place. What would the least uf that it could get away with?
Greg, what caps did you end up using? (Space is an issue)
Guys thanks for all of the help.
Cheers
Greg
"Live each day as if it is your last"
Old 8th May 2013, 10:44 AM   #173
Originally Posted by rsavas View Post
Hello folks,
Thx Rick
I will sort something out for you
Old 8th May 2013, 11:13 AM   #174
3GGG is offline 3GGG  Australia
Cheers
Greg
Glad it is sorted mate. I used Auricaps Auricap Audio Capacitors, I am sure there are better options but your room will probably play a bigger influence
Old 8th May 2013, 12:40 PM   #175
Thx Greg, glad to hear that you solved the problem & are enjoying this fine design. What phono cartridge/TT are you using?
O/P couling cap depends on the input R(Z) of the following stage (usually around 50K) and how much low pass filtering is required. Are you using the rumble filter? I would say 3.3uF would probably be a minimum with a 50K load. -3db= 1/(2piRC) ~1Hz
Rick
Old 15th May 2013, 09:54 AM   #176
Hi Rick,
Apologies, the family came down with the flu!
Back on track, I will forward the BOM this weekend as it needs to be cleaned up.
Im using a stacked platter lenco with Grado sonata ref with a ruby cantilever etc from expert stylus.
cheers
Greg
Old 15th May 2013, 01:20 PM   #177
Hi Greg,
Thx for getting back to me, no rush for the BOM, hope you & the family are feeling better.
Rick
Old 22nd May 2013, 10:02 AM   #178
fasterbyelan is offline fasterbyelan  United Kingdom
fasterbyelan's Avatar
Hps 5.1
I am coming to the end of the HPS 5.1 build and now testing the phono amp. I have a couple of questions Ė
Regarding the input JFETís, the designer quotes ďThe JFETs Vds is kept to around 3V, so that they don't heat up (affecting the noise) and also no hot carriers injection occursĒ.
I have a Vds of 3.34V as a result of the reference from the 2 GLEDís being 3.96V. I am using an Agilent Green LED (part no HSMG-C265). I could replace these for an orange type from the same manufacture, this would give around 3.7V ref or I could reduce the current through the LEDs.
The questions I have are-
1.Should I be concerned that the VREF is slightly higher? I calculate the power dissipation to be 36mW at present for each JFET, reducing the reference would give approximately 30mW
2. Does reducing the current through the LEDís increase their resistance and hence noise? (I donít feel this is a sensible route as the value of the I limiting resistor will need to be increase significantly).
Karl
Lenco - cause it's got soul!
Old 22nd May 2013, 07:47 PM   #179
h_a is offline h_a  Europe
h_a's Avatar
Hi Karl,
while I'm not Ovidiu, I would say no on both accounts. No need to worry - Enjoy! Hannes
High Octane phono preamp Wiki
Old 26th April 2015, 12:39 PM   #180
rrrremus is offline rrrremus  Germany
Lesson learned : Lower the rail voltages on your HPS 5.1 Amps.
I built my HPS a few years ago and since then have only powered it up a few times in the weekends. A few weeks ago a channel went dead on the HPF. Since i did not have the time to find out what the problem was at the time, i bypassed the filter. Today, the amp would not work at all. I opened it up and measured the outputs before the caps where i read -21.98V DC.
The op-amp rails both measured just above 22V. I remember that when building this beast, i set the rail voltages lower than Ovidiu's schematics, somewhere just above 21V. It looks like time and the high temperature have taken their toll and blew all of the 22V rail op-amps. That is 6 of them
I advise you check your rail voltages and lower them if necessary.
Hps 5.1Hide this!Advertise here!
HPS 4.0 phono stage syn08 Analogue Source 347 3rd November 2013 02:44 PM
Hps 5.0 syn08 Analogue Source 9 2nd May 2010 02:33 PM
Copyright ©1999-2017 diyAudio
