Old 14th May 2010, 06:39 AM   #1
Roushon is offline Roushon  India
Default A PCB-design for Phono-pre-amp
Here is a single-sided pcb-design (with two jumpers) for a phono pre-amp circuit based on the National Application Note AN-1651.
I request for suggestions and corrections in the design.
Roushon
S. Roushon
Old 14th May 2010, 12:01 PM   #2
Joachim Gerhard's Avatar
R18 and R19 have been swapped.
Old 14th May 2010, 12:02 PM   #3
The output buffer may not be neccessary.
Old 14th May 2010, 12:21 PM   #4
Thanks Joachim. R18 is 38.7R. I corrected it now. I am following the Topology 2 (Active/Passive) in the application note. Half of IC4 is not used, so
I made a unity gain buffer out of it. I know it is not required, but it is not of any harm if added I hope.
Roushon
S. Roushon
Old 14th May 2010, 12:39 PM   #5
Putting a buffer in my sound better when you drive long and demanding cables, so yes, it does not hurt. You could also build a switchable subsonic filter.
Old 14th May 2010, 01:01 PM   #6
That is a very good idea. Thank you very much. I will work on to convert the
unused opamp into a subsonic filter.
Best regards
Roushon.
S. Roushon
Old 14th May 2010, 01:06 PM   #7
On the pcb: do not use 90 deg. anles on traces. In the etching process (especially home-made boards) undercutting at the anle could happen). Use only obtuse angles (135 deg. or greater). The star grounding you are employing is not required here. It is used in high power systems where a ground lead could be modulated causing hum and feedback. Not using star grounding can reduce the pcb size. E
Old 15th May 2010, 06:39 AM   #8
Thanks a lot for your suggestions. I will make the angles smooth. About the
ground connection can I make only one ground connection from the board, meaning, is fusing all the ground end from both upper and lower parts of the
pcb to a single point OK?
Roushon
S. Roushon
Old 15th May 2010, 09:05 AM   #9
binspaul's Avatar
Send a message via Skype™ to binspaul
I am also working on the same app note. But, I am using hard wiring with ultra pure silver wires instead of the PCB's. Also, I am using single opamp's instead of the dual version. What is the supply you are using ?
Best regards,
Bins.
Roushon
Old 15th May 2010, 12:24 PM   #10
I will be using +-15v as shown in the application note made using LM317 and LM337. I have surface mount type ICs, so I need a PCB.
S. Roushon
Phono pre amp nhuwar Tubes / Valves 2 11th December 2008 06:16 PM
PCB for Pearl Phono Pre sonix Pass Labs 2 4th March 2006 11:41 PM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
Phono Pre-Design Input philipbarrett Tubes / Valves 22 5th November 2005 04:20 PM
Any phono pre-amp recommendations? bm_mode Solid State 17 28th August 2003 12:33 PM
Copyright ©1999-2013 diyAudio
