| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Is there a signal generator that incorporates an inverse RIAA circuit available in the market? I don't want to use an external Inverse RIAA circuit because it may be incorrect (and difficult to calibrate) and induces hum.
#2 |
I've never seen such a thing, but my experience is that inverse networks have to be physically placed right at the preamp input, and often a heavy ground strap run to the chassis, otherwise the hum levels will contaminate distortion measurements. RIAA compensation in the signal generator might not be useful and it probably wouldn't be as accurate as what you can build yourself.
Conrad
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
If you are using a data acquisition card, you can use the polynomials for the correct time constants to just massage the data in situ.
Numerator: 1 + X* 3.255e-3 + X^2 * 2.385e-7 Denominator: 1 + X*318e-4 + X^2 * 1e-12 I wrote a program for my HP3577a network analyzer to do this via the GPIB, (can't find the program) you should be able to do it with a sound card -- if the data on the sound card is valid to >50kHz. |
#4 |
I have a 24/96 inverse riaa wav file with 100 10th octave tones placed at exact bins for a 64k FFT. The phase is randomized so it is psuedo-random. Better than .0005dB, I've been using it to verify biquad digital RIAA filters.
2012, our time is running out. Last edited by scott wurcer; 7th May 2010 at 03:37 PM. |
#5 |
The one and only
#6 |
I figured he might want something cheaper. It is amazing, rippling only a four coefficient IIR filter through an unequalized file is better than .00057dB and +-2 degrees from minimum phase and perfect channel to channel match. Better than any set of R's and C's. No noise or distortion either.
2012, our time is running out. |
#7 |
There is this: Hagerman Technology LLC: iRIAA Filter for Phonostage DIY Kit
#8 |
You could put a standard or computer function generator into this:
Reverse RIAA Equaliser |
#9 |
Here is an article with a simple inverse RIAA network. http://waltjung.org/PDFs/A_High_Accu...AA_Network.pdf
Ray |
#10 |
Many thanks for the input.
| Inverse RIAA revisited | Pjotr | Analogue Source | 0 | 28th December 2007 02:32 PM |
| looking for a signal generator | Ahmad_tbp | Solid State | 21 | 8th September 2006 11:37 PM |
| Inverse RIAA | davidsrsb | Analogue Source | 16 | 5th February 2006 04:59 AM |
| signal generator help | hizz_eye | Solid State | 2 | 3rd March 2005 10:25 AM |
| Inverse RIAA | Hoffmeyer | Solid State | 7 | 24th November 2001 04:54 PM |
| Page generated in 0.10309 seconds (77.62% PHP - 22.38% MySQL) with 11 queries |
