Angling for 90° - tangential pivot tonearms - Page 58 - diyAudio
Old 8th November 2013, 04:03 AM   #571
directdriver's Avatar
Default Schröder LT tangential tracking tonearm
Drawings from the recent patent!
Old 8th November 2013, 04:17 AM   #572
tnargs is offline tnargs  Australia
Yes, I saw and heard a Thales Simplicity a couple of weeks ago. Nice!
Old 9th November 2013, 12:20 AM   #573
Frank,
Congratulations on your new patent! I hope it adds good things to your life!
Andy
Old 9th November 2013, 08:21 PM   #574
Schröder LT tonearm on a Kodo The Beat turntable by Steve Dobbins in the recent RMAF 2013, images courtesy of partimeaudiophile.com. Notice the non-offset headshell.
Old 27th November 2013, 04:15 PM   #575
Very impressive indeed. Couple of months we here, rather smart guys, tried to figure out what lies on the bottom of this arm, still with no result. This is where ingenuity is: very simple, elegant and effective design with no unnecessary features, nor under- , nor over-engineered. Bravo, Frank, you are still able to amaze us, picky spoiled audiophiles, after 100-something years of tonearm development history.
Old 27th November 2013, 11:13 PM   #576
There's no mystery, it's been obvious from the first photos.
Old 28th November 2013, 03:08 AM   #577
Agree.
To those still not sure, take another look at the first photo blown up and spelling out the obvious with parts number in the patent...
Old 28th November 2013, 02:56 PM   #578
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Amazing that the leverage needed to pull this arc across the record works out.
This doesn't look like it would work well with high compliance MC's, but most would mate this with medium to low compliance ones anyway so probably no issues.
A very interesting and unique design that is just begging for a DIY attempt
David
Old 28th November 2013, 03:23 PM   #579
It works fine with cartridges of super high compliance(>30CU) too. The force required to deflect the arm sideways, translated into forward motion is always less than 3,5milligrams. Try to find an arm with captive bearings that requires less force to overcome stiction.... it's the wiring that becomes the limiting factor at this point.
And don't forget that this arm has greater "leverage" than conventional linear trackers, due to the much shorter travel distance (~30mm vs. 100mm) for the same radius covered.
Frank
Old 28th November 2013, 04:05 PM   #580
AVWERK's Avatar
This "forward pull" is an added feature along with the bearing arrangement already present.
I,m trying to wrap myhead around how say, an air bearing doesn,t have this feature even though you place the 30mm vs 100mm in the same camp.
Their in different camps. One has no friction (air) across the record and yours needs considerable friction (bearings and forward arc) to accomplish the same thing in its 30mm requirement
Your design is very clever and would love to hear it someday.
David
Gliding for 90° - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 3rd April 2016 11:40 PM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 07:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 04:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
Copyright ©1999-2017 diyAudio
