Old 16th June 2013, 02:46 AM   #541
directdriver is offline directdriver  United States
directdriver's Avatar
Default Schröder LT tonearm
Terrific images of the innovative Schröder LT tonearm. Notice there is NO offset at the headshell. Also notice the magnetic guiding system under the base plate. If I'm interpreting the pictures correctly, looks like a pivoting armature holding a magnet following a curved steel rod path and therefore no mechanical contact.
Frank Schroeder is one clever guy!
More images on post #443.
Old 16th June 2013, 07:51 AM   #542
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Classic ton arm with magnetic antiskating.
Regards zeoN_Rider
Old 16th June 2013, 02:46 PM   #543
It has nothing to do with antiskating.
Old 17th June 2013, 08:51 AM   #544
Default SchuchTronic & WKarlson
On post #61, I posted about a WKarlson tonearm that I am still not sure if it's a tangential pivot tonearm like the SchuchTronic arm. But there are striking similarities in using strings, round headshell, and aesthetics. Both look like Frankenstein but fun.
Compare below.
SchuchTronic tonearm
WKarlson tonearm
Old 25th June 2013, 02:50 AM   #545
More pictures of the wacky SchuchTronic tangential tonearm from a German website.
Old 25th June 2013, 02:16 PM   #546
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Finally I understand the principle.... quite clever... as the stylus moves inward to the center of the platter, the magnet pulls the arm base following the curved metal, causing the pivot to change position
RC
Old 25th June 2013, 02:27 PM   #547
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I heard that arm at Franks home.
It sounds awesome and is a perfect example how simple it can be.
Old 25th June 2013, 02:32 PM   #548
nhinstruments
RCruz's Avatar
Did you also listen to the Thales tonearm ?
RC
Old 25th June 2013, 05:29 PM   #549
Exactly. The clever thing is that it never had to use any linear bearing or any contact type of bearing, hence the low friction. The shape of that curved metal is crucial to the tangential accuracy, though.
Gliding for 90° - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 3rd April 2016 11:40 PM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 07:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 04:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
