Old 23rd May 2013, 07:55 PM   #471
stevieg is offline stevieg  United Kingdom
I can see two tensioned springs - neither on the plane of the pivot, but possibly equidistant from it, and what seems to be a contrarotating balance weight. Hmmm. Are we moving into the "great theoretically if stuff always worked the way it is supposed to"?
Cheers Steve
steve
if it ain't broke, I ain't fixed it
Old 24th May 2013, 08:34 PM   #472
directdriver is offline directdriver  United States
directdriver's Avatar
This reminds me of your dad's quote: "The Vincent motorcycle was a collection of solutions looking for a problem."
Old 25th May 2013, 10:04 AM   #473
Cheers for that. Made a sunny morning even finer. All we need now is someone to explain how this arm works. My guess would be the the springs and tensioned strings would buzz at some frequencies. Happy to be proved wrong.
Cheers Steve
steve
Old 27th May 2013, 08:18 PM   #474
Default Schuch Tronic Modell No. 1 (Prototyp)
Old 28th May 2013, 07:44 PM   #475
Can I see a bias compensation weight? Why?
Cheers Steve
steve
Old 29th May 2013, 11:30 AM   #476
Sprags is offline Sprags  United States
Seems to me the simpler solution would be to not add complexity to the design of the tone arm but rather design a device that will move the platter along a path that will keep the stylus tangent as it should be.
This device can be designed and built to keep the platter as stable as necessary for proper playback of the vinyl recording relative to the stylus and system as a whole yet still move along the required path. Something cam driven perhaps with some kind of vision system to 'see' where the stylus is located while functioning as intended.
If someone is interested in pursuing this concept contact me.
Old 29th May 2013, 08:52 PM   #477
Anytime the the stylus does not point to the pivot as a straight line, there will always be skating force, no matter how small even in a tangential pivot arm like the SchuchTronic or Thales Simplicity, hence the bias compensation.
Old 29th May 2013, 08:57 PM   #478
Wouldn't it be simpler to move the base of the tonearm than moving a spinning platter? I think a servo sliding armboard or armbase is closer to the mark. This thread is focused on mechanical design but we, of course, can flirt with other schemes. Thanks for chiming in.
Old 30th May 2013, 12:17 AM   #479
Originally Posted by Stefanoo View Post
I see you posting a ton of pictures with different very expensive cartridges! Are those yours??
No, they're not. The pictures are all from the internet. I just accumulated all these pictures on this thread for all to ogle. After all, we all like audio porn, right?
Old 30th May 2013, 12:18 AM   #480
Perhaps you are right about the servo-motor driven tone arm base...I overlooked that concept. I was looking more at the multi-link or cable controlled phone cartridge pivoting systems. Cables and links just make me think of a loss in precision for stylus orientation.
Gliding for 90 - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 4th April 2016 12:40 AM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 08:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 05:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 05:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 09:03 PM
Copyright ©1999-2017 diyAudio
