Old 10th December 2017, 06:43 PM   #1591
lcsaszar is offline lcsaszar  Hungary
Hi Carlo, a pendulum moves on arc, not linear. Your string should be very long so that the pickup can move horizontally, not elevating from the disc. Otherwise very clever measuring setup!
Old 11th December 2017, 01:55 AM   #1592
dtut is offline dtut  United States
Carlo,
I've been enjoying your elegant experiments and the interesting results. I'm building a mock-up pivoting arm which I hope will let me measure both stylus drag and 'skipping' forces. I've been thinking about niffy's posts, too, and I'm going to try an experiment with one of my old PLTs.
I'll try to post in the next couple of days.
Doug Tuthill
Old 11th December 2017, 07:19 AM   #1593
nocdplz is offline nocdplz
nocdplz's Avatar
You 're right Icsaszaar, completely, but for angles <4 degrees the difference is so small that even the physicists do not care. My will was simply to see - and show - what would have been the displacements with the theoretical values, compared to the real ones. Photos speak for themselves.
Doug, i'm looking forward to your work, and the data you will find.
Really, start thinking about measuring the skating, it would be nice to start discussing concrete data.
Niffy: thanks again for your contribution. Could you please post your rig for the static measurements? I would like to make precise measurements of carts -
Carlo
Old 11th December 2017, 07:35 AM   #1594
nocdplz's Avatar
Icsaszaar, sorry. I reread your post, which I misunderstood. Look better at the photos: the pendulum rises but the stylus that is placed on a small arm with a vertical pivot obviously remains on the disc. If not, what would you measure?
Confusion starts maybe from the photos of the pre-test with weights and pulley : there is needed that the whole mass raises (and there is not a disk).
The mass of pendulum 41gr = 0.4 N is given by rig + small arm + counterweight - VTF. Variations of VTF were compensated with small 1/2 g weights.
carlo again
Old Yesterday, 11:15 AM   #1595
nocdplz's Avatar
Sorry, I said not to be qualified: converting N to mN i've lost a little dot (little, but very important, of course): too many 0 on my pocket calculator
This new table hopefully correct.
Carlo
Gliding for 90 - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 4th April 2016 12:40 AM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 08:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 05:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 05:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 09:03 PM
Copyright ©1999-2017 diyAudio
