Old 15th September 2017, 02:29 PM   #1511
niffy is offline niffy  England
Hi DD,
I fear that your current design is going to suffer from lateral instability where the vertical arm rests on the two round rails. I think that the contact points in the grooves in the bearings are not going to be sufficiently rigid to prevent any lateral rotation at this point. (The groove will allow a little rotation before rolling) Any play in the bearings will also allow a small amount of lateral rotation. I would also recommend against ball race bearings if at all possible due to the aforementioned chatter.
Niffy
Gliding for 90 - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 3rd April 2016 11:40 PM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 07:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 04:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
Copyright ©1999-2017 diyAudio
