| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 |
Salsa is a pretty good cart for the money, another brilliant match on the RB's is the
AT-OC9 ml2. |
#22 |
May I suggest you investigate the arm or setup? While it is true that a 103 in a Rega arm does not sound ideal, when it comes to tracking there is nothing wrong. I have mounted several DL-103s in Rega (and Technics) arms, and in all cases did I get secure tracking at 2.5g under all circumstances, including the HFN test LP fourth (torture) band.
bring back dynamic range |
#23 |
Hi Werner,
My Rb300 was set up correctly and well modified, it is a good arm but not suited to the DL103. I may have slightly overstated how crap it is with the 103. I have tried the 103 in my Moerch with a 12" blue armwand (magical) It also works brilliantly in my beaten up ancient atp12t, leaves the Rega for dead. |
| Which Cartridge? | algoart | Analogue Source | 10 | 3rd October 2009 09:51 PM |
| Connoisseur cartridge | petronius | Analogue Source | 3 | 25th January 2008 09:26 PM |
| Cartridge wear | nghiep | Analogue Source | 5 | 15th November 2005 12:57 AM |
| a new cartridge.... | marcanto | Analogue Source | 2 | 29th September 2005 07:24 AM |
| the right stylus/cartridge | solonbro | Analogue Source | 38 | 2nd April 2005 09:24 PM |
