cartridge for RB251?
Old 28th April 2010, 04:34 AM   #11
stonedeaf is offline stonedeaf
Default Why no DL-103
Am listening to Bill Evans thru a RB-250 and DL-103 as i type this.Added two - 2.5g weights plus a bit of BlueTac between cart and headshell. 2.5 grams VTF leaves the standard small counterweight at the far end of the arm ,anti-skate is set at about 1/2 gram. Plays everything on the HiFi News test disc.Most of my records are warped and this combo doesn't seem to have any particular problem tracking them.
I will admit it probably took a good 50 hours before my ears were used to this arm/cart. My experience with this cart is it does sound a lot better thru a SUT @40ohms compared to just feeding it into a 133 ohm MC gain stage.Initially had the arm set high - needed to bring it down dramatically to where the top of the cart was roughly parallel with the record surface (lined 3X5 " index card was helpful here) -KK was right.
My only real gripe is that it does seem to have a magic ability to pick up a nice matt of fuzz off of used records ( more time with the RCM).
Old 28th April 2010, 07:07 AM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
OK I start to understand the issues of arm mass in combination of the cart compliance. That was helpful.
Still, not having any cartridge currently it seems better to go for a good combination at the outset.
I'm picking up my TecnoDec with the RB251 this weekend. I'll see what cartridge the guy uses, but he won't sell it.
jd
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 28th April 2010, 09:18 AM   #13
cjcc67 is offline cjcc67  Australia
I'm interested in trying the Doric on my P3 with the RB300 arm. Joachim, amongst your prolific number of circuits posted elsewhere there must be a suitable pre_pre amp for my tube preamp along with a solidstate version to compare to the tube using a line level input all of course with the powersupply. Sorry for being lazy i was trying to find them on the other thread but you are too busy!!
Ps used Doric low hours on audiogon approx USD$600
Old 28th April 2010, 03:01 PM   #14
jan.didden's Avatar
I've ordered an Ortofon MC Salsa, from the data I've seen it should be a good match for the RB251. Any comments anybody?
jd
Old 28th April 2010, 04:23 PM   #15
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I think that is a good choice. In the old days i was a happy owner of an MC20.
I like that your new Cartridge has a fine line needle. Needs really good adjustment though.
The parameters ( 0.35mV, 7 Ohm) are not much different from my Lyras so my phonostages will work well. Compliance is ok too for the Rega.
Old 28th April 2010, 04:43 PM   #16
jan.didden's Avatar
Yes fine line needle. VDH would probably kill me if he knew
jd
Old 28th April 2010, 04:57 PM   #17
In fact Dr.Weinz from Idar-Oberstein made the first "fine-line" needle. It was called the "Paroc". Long before Van Den Hul.
Old 28th April 2010, 06:09 PM   #18
jan.didden's Avatar
Figures, living in the middle of (semi) precious stone country.
jd
Old 28th April 2010, 06:23 PM   #19
Yes, sadly he died much to young. Idar - Oberstein is still the center of precious stone grinding in Germany.
Old 28th April 2010, 08:33 PM   #20
coredump is offline coredump  Germany
These carts I have found decent enough with an RB300 (so they should work just as well with a 251):
* Goldring 1042 - very sensitive to phono amp capacitance, I had best results with 120p (+ cable capacitance). Nice round and full sound, lots of "slam", wide soundstage.
* Ortofon VM Silver - same league as the 1042, but different sound. Fritz Gyger 70 stylus, needs careful setup. Hardly any audible inner groove distortion, very well-defined (if somewhat small) sound stage with pin-point imaging. Slightly bright.
* Denon DL160 - budget cracker. Good stylus with little inner groove distortion. Extremely large sound stage with good tonal colours. Not the most "musically agile" cart, but also never completely disappoints. Low output MC, works with standard MM stages. Input impedance should be lower than the normal 47K, in my system 3K worked great.
I did not like the 440MLa (seemed to trigger arm resonances) or the Benz Micro Gold (dito).
Best,
Oliver
cartridge for RB251?Hide this!Advertise here!
Which Cartridge? algoart Analogue Source 10 3rd October 2009 09:51 PM
Connoisseur cartridge petronius Analogue Source 3 25th January 2008 09:26 PM
Cartridge wear nghiep Analogue Source 5 15th November 2005 12:57 AM
a new cartridge.... marcanto Analogue Source 2 29th September 2005 07:24 AM
the right stylus/cartridge solonbro Analogue Source 38 2nd April 2005 09:24 PM
