| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
My ST-S550ES sound good five minute then the ssound is dirty .
if i change the frequency manually and i tune to the same frequency , it sound good it's not easy to hear some music ! a little help thanks
#2 |
i have ths manual service
here the shematic
#3 |
Being able to retune, and it then being OK suggests more of a misalignment issue to me.
Is there any mention of an AFC adjustment in the manual. Don't twiddle anything, but if any of the cores in the transformers are adjustable see what just placing a metallic trimmer in the core does as that alters the tuning without you twiddling. See if the sound come back.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
AFC ?
a manual service thanks |
#5 |
It's T301 and T302 on the circuit diagram.
RF work is so difficult and requires specialised gear so anything you alter is at your own risk ![]() Any feritte cores need the correct tools to adjust them (you can make them by filling suitable nylon or plastic material). If you try and use a small screwdriver that doesn't fit they will crack very very easily. And I'm just "guessing" that this would hopefully correct the problem. Try what I said earlier and try and alter the tuning of the coils by placing a metallic driver "into" the cores without turning them. Also putting fingers on and around the PCB and components in that area might give you an idea... very non scientific but it works.
#6 |
I have adjusted T301 and T302 , and it sound good now
thanks Mooly |
#7 |
Your welcome.
Pleased you were able to fix it.
| Someone has offered me a Sony ST 5130 tuner, should I take it ?? | Shoog | Analogue Source | 6 | 30th June 2010 09:10 PM |
| About power transformer of technics st-8077 tuner | jorge2 | Analog Line Level | 0 | 21st June 2008 09:04 AM |
| Sony ST 5150 tuner SM | Praudio | Parts | 0 | 3rd January 2008 04:03 PM |
| Sony ST-S310 tuner trouble | hiwiho | Analogue Source | 5 | 5th November 2006 10:49 AM |
| Sony ST-J55 Tuner Mods | kestrel200 | Solid State | 9 | 19th March 2005 02:38 PM |
| Page generated in 0.09704 seconds (73.76% PHP - 26.24% MySQL) with 11 queries |
