Balanced input all DC coupled RIAA preamp - Page 12 - diyAudio
Old 27th August 2012, 02:29 PM   #111
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I would like to see yout wire bender Frans
Nice work bksabath
RC
Old 27th August 2012, 06:54 PM   #112
FdW is offline FdW  Netherlands
FdW's Avatar
Nice work bksabath
Here it is, the (c) FdW 'Wire bender' it makes nice 'square'-bended, and 'un-stressed', very even (sized) bended-resistors.
Old 27th August 2012, 08:16 PM   #113
nhinstruments
RCruz's Avatar
Super cool... I will build one ASAP... I am actually working in a "Menuiserie" so I can have easy access to all sorts of wood and corresponding machines.... (I am also considering building a pair of speaker enclosures )
RC
Old 27th August 2012, 09:36 PM   #114
FdW's Avatar
I'm sure that the speakers will be the easy part thanks for like-ing it
Old 28th August 2012, 09:39 AM   #115
FdW's Avatar
Originally Posted by FdW View Post
Can't see anything wrong
BTW you need a resistor wire bender, I will post a picture of mine later today.
There is one thing wrong, IMO you should first have done the full build of the raw, then the pre- and then the clean power supply, this to be enable you to test each step before connecting the next step. By building the input stage very early you risk (there is not much risk ) it at every step of the way.
Old 28th August 2012, 09:44 AM   #116
FdW's Avatar
Originally Posted by Bksabath View Post
Yes I know never got around to get one
Still I am pretty made up with the smd welding
Now that I got around to it is pretty easy
Just a bit of solder paste on track and hold chip with crocodile clip
Just touching with wet solder tip does the trick
About SMD. I do like non-SMD, old school through-hole, constructions, and I like them spacy , not maximum compact. IMO spacy circuits sound better than very compact, as normal for SMD constructions, circuits.
Old 28th August 2012, 09:45 AM   #117
Banned
Quite right
Just bit and pieces out of stock or Postman waiting for house to be empty
Old 28th August 2012, 09:50 AM   #118
FdW's Avatar
Quite right
I can not wait to see/get a listening report from you
Old 28th August 2012, 03:56 PM   #119
Banned
Right no presssure then
Today I have been making those
Shuld take care of same vibration when mounting PCB
Old 28th August 2012, 09:08 PM   #120
FdW's Avatar
Nice, I did mount my boards on nylon struts and bolts in the boxes, then the boxes are mounted on separate nylon struts and bolts to a 'floating' sub-frame, floating (not truly) by being flexible. Due to the high mass of the 2mm thick copper box the whole system is mass-dampened.
RIAA with balanced output? roger-k Chip Amps 4 1st May 2010 11:27 PM
DC on preamp input sharpi31 Tubes / Valves 10 4th May 2008 02:19 AM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
OPA1632 for balanced RIAA preamp.? Ultima Thule Analogue Source 1 7th June 2004 09:06 PM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
Copyright 1999-2017 diyAudio
