Yaqin MS 12B phono amp- reviews
Old 14th May 2012, 07:28 PM   #51
Join is offline Join  Norway
Hi!
I have owned the MS-12B pre a couple of years now. A friend with electronic skillz recommended it.
So, purchased it, and he helped me do the mods.
He told me to get JJ ECC82/ECC83(I think).
And he replaced the two caps that looked like this:
With a matched pair of this russian NOS paper-in-oil caps:
It really changed the sound from average to outstanding! It sounds very expencive, but is not.
About the pot, is it a dual 100kOhm? I got a blue alps like that and if it is a match it will go in there.
Old 14th May 2012, 07:39 PM   #52
Rolli666 is offline Rolli666
Default Resistor
Still need to know if I can replace that 15 ohm 7 watt with a 22 ohm 5 watt? Thanks for the other info though.
Old 14th May 2012, 07:53 PM   #53
Did you use two matched
POI's for each 1 uf cap
Old 14th May 2012, 08:30 PM   #54
No, sorry. One per channel.
Old 15th May 2012, 01:17 PM   #55
awkwardbydesign is offline awkwardbydesign  England
If no-one else will help, try this; Ohm's Law Calculations With Power
If I have it right, you want to drop 10 volts, as the heater transformer is 16v, x 1.4 rectified and smoothed, =22v. 22-10=12v. Using the calculator, I get 4.5w dissipation, which is pushing it a bit for a 5w resistor. As I use a 20R resistor to get 12v (22R gave me 11v), that dissipates 5w, so I got a 10w resistor here- eBay - The UK's Online Marketplace. He doesn't seem to have any more at the moment, but I have a spare if you need it. Why do you want to use a 5w? 10w WILL fit, only just.
Hopefully someone more expert will help, but that is the best I can offer.
Old 15th May 2012, 01:33 PM   #56
By the way, removing or bypassing the volume control, output board, relays improved things. I also removed the 2 push button switches and put in a pair of WBT RCA sockets instead (I already had them), so the phono inputs are on top. Replaced the RIAA resistors with Takman metal films, and the caps with Russian teflons. Changed the input loading resistors to 1megs (for my Decca) and then paralleled them to get what I want. DIL single pin sockets to make them plug and play. Outputs from RIAA section or normal output via different sockets. At the moment it sounds better going through both sections, but I have TVC preamp, so YMMV.
Old 15th May 2012, 01:54 PM   #57
migkiller1971 is offline migkiller1971  United States
This is a absolutely fantastic Phono/preamp if you are starting to get into tubes. I can't recommend it enough. I've added a better Volume pot, I have 1 UF sonicap gen 1 bypassed with sonicaps gen 2 .01 UF caps. I've added bradley allen gridstoppers. I have caddock's 47K resistors. I've also added some bypass caps in the powersupply. For the price, its unbeatable. This preamp has given me more joy than the $1200 Cornet 2 I have. I have to double check everything and put up the Yaqin for sale. All its doing is collecting dust.
Old 15th May 2012, 02:01 PM   #58
Here is the insides: And yes, those are Blackgates capacitors in there.
The UnderBelly: you can see the Bypass Caps, 47k resistors, Gridstoppers
Old 15th May 2012, 02:57 PM   #59
Have I read that right? Why is the Yaqin for sale if it has " has given me more joy than the $1200 Cornet 2"?
Also, is the 4 pin connector from the tranny original, or did you fit it? And my unit is a 240v model so 20R is better for the 5814 (ECC82) heaters.
Old 15th May 2012, 03:31 PM   #60
How much do you want for it?
Yaqin MS 12B phono amp- reviewsHide this!Advertise here!
Yaqin MS-300B SET amp Rodango Tubes / Valves 18 26th November 2010 08:09 AM
Help - MS-6V6 Yaqin schematic wfmali Tubes / Valves 5 6th April 2010 07:55 PM
Yaqin Valve Amplifier UK Sales & Service marktravuk Vendor's Bazaar 3 16th November 2007 04:55 AM
Research Project: Need your op-amp reviews! zagisrule! Chip Amps 5 2nd May 2007 06:33 PM
Tube power Amp matching with SAE Mark M pre amp and AR18 speaker or MS 25i soultribe Tubes / Valves 1 13th August 2006 11:08 AM
