Precision op-amp RIAA pre..
Hi all,
I have designed (filter circuit is inspired from an internet project that I already forgot) that about one year ago. However couldn't find any chance to make it until now.
It's a mixed filter stage (passive+NFB) and battery powered (4.8v) MM type preamp. in the simulation its RIAA curve accordance in 20Hz-20KHz band is +/- 0.05dB max with 1% resistors and 5% capacitors. I have already purchased 0.1% resistors and 1%capacitors (all MKP except 220µ) from Farnell. So I am expecting better results.
Since its battery powered I am using a virtual ground circuit that provided by a TLE2426. Its actual gain is ~41dB (@1Khz). It has capability to upgrade for MC heads with a simple resistor changing. The opamp (OPA4353) I use is an audio grade BB CMOS opamp since its rail to rail and low power one.
LM317 stage is just for battery charging nothing about the circuit.
So may you share your advices about my RIAA preamp please..
Thanks in advance for anykind of comment or recommendation..
rjm
Joined 2004
5% tolerance capacitors implies +/- 0.5 dB RIAA accuracy, your 0.05 dB figure is calculated for the components as exactly the stated value.
The circuit itself is straightforward and reliable... except for the headroom issue brought up previously. If your want the simplicity of running from a low voltage battery an all active RIAA filter would be a better option.
Right.. But if you take a look my filter design and opamp specs then you'll see my pre will be a really precision RIAA opamp!
I cannot see any reason that a "rail to rail low distortion and low noise" opamp will not give good results with that level of supply voltage! Which is really comparable with LM4562, OPA604, OPA134, AD797 type popular opamps..
Ozgur,
Precisely following the anti-RIAA curve is one thing. The final sound quality is determined by many other factors, starting from the choice of the gain element (opamp and type thereof, BJT, FET, tube), topology (feedback or passive equalization), power supply (3-legs, discrete, battery) etc. I also built a phono similar to yours. It was technically "perfect" but sonically inferior.
I am absolutely aggree with you..
My components arrived just this morning.. I guess I will finish the project by this weekend and hear the results next week.
My filter topology, component selection and psu (which is only battery) is best I can do. I hope the results will the best also;)
I'll inform you about the impressions next week.
Thanks for the sharing.
