Custom made turntable plinth... Custom made turntable plinth... - Page 3 - diyAudio
Old 21st April 2010, 08:14 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Here is the BD1 i did up...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st April 2010, 11:33 AM   #22
Jim Leach is offline Jim Leach  United States
You guys really have some great designs here.
I am proud to be a part of the community!
"When the world is running down,
you make the best of what's still around."
Old 21st April 2010, 06:08 PM   #23
dtut is offline dtut  United States
This one is foam and fiber glass with 5/16 Masonite inside to attach the parts - AR platter and bearing, BIC motor, and DIY tensioned string arm. Sort of a musical surfboard. It works well even though the materials are improbable and not for everyone. I wanted a unique shape, but there sure is something fine about the classic simplicity and proportions of Jason's bamboo Lenco.
Jim - Thanks for posting #17. Great information and a lot to think about.
Doug Tuthill
Old 21st April 2010, 06:41 PM   #24
moray james is offline moray james  Canada
Doug your table looks beautiful almost like a concrete or stone plinth very interesting effect. Any more pictures under the hood? I really like your treatment of the top of the plinth, what material did you use for that?
I am sure that bamboo would make a fine plinth material but it sure is hard on carbide cutting tools.
moray james
Old 21st April 2010, 07:29 PM   #25
Moray,
Here are the innards in all their glory. The straps to the motor are neoprene. The BIC is noisy, but the neoprene isolates it completely. I use neoprene for the platter mat, too. The drive pulley is wood with washers top and bottom. Entirely by coincidence, a 3/4" hole saw with a 1/4" guide bit made the pulley. Just luck with that one. The platter and arm don't float like they did in the original AR. The entire outside of the plinth is foam and fiber glass. The dark matte grey on the top is Rust-o-leum spray can paint. They've introduced a new line I really like. It holds up to use and cleaning very well. I'm glad you like the polished stone look. That's what I was going for, although the red accent is a little more prominent than I intended.
Doug Tuthill
Old 21st April 2010, 08:18 PM   #26
My pleasure Doug!
Take nothing I say as gospel; just use it as a guide to let your ears decide what is right...
Old 21st April 2010, 08:34 PM   #27
Doug: nice job on the plinth very professional looking job.
I rather like the red effect it almost looks like a blood stone.
I have seen some very interesting effects generated in colored concrete by adding either fine steel wool, brass wool or copper wool. This yields a very nice colored marble effect with the steel producing iron oxide (rust red) the brass makes a blueish oxide and the copper is green. When the outer surface is polished the look is very unique. I have seen steel and brass wool but have never come across copper wool perhaps it was hand made for the application. I saw this in a concrete design book decades ago.
moray james
Old 3rd April 2011, 03:38 AM   #28
djn is offline djn  United States
djn's Avatar
Here is the plinth I made for a Rek-O-Kut K33H and lengthened Infinity Black Widow arm. I am now making 3 of them for others.
Old 3rd April 2011, 04:02 AM   #29
limono is offline limono  United States
Ooohh beatiful Mermaid, come and sing your poisonous tune.......
Old 1st December 2012, 02:11 PM   #30
Bernauer is offline Bernauer  United States
Default Lengthen Infinity Black Widow Tonearm!!!
djn! Please give some details about how you lengthened the Infinity Black Widow Tonarm. I just bought one with the specific idea to lengthen it. I didn't think anyone else had tried it. I have access to some very high quality carbon fiber kite spars and carbon fishing rod blanks that look very similar to yours. Would be very excited to hear from you how you did it. One of my main questions is whether the factory carbon arm is glued or somehow screwed into the aluminum pivot mount?
Thanks in advance :-) !!!
Custom made turntable plinth...Hide this!Advertise here!
where can I have a custom made heatsink? Stefanoo Solid State 47 26th January 2012 06:06 AM
A new plinth for an old turntable... simeon_noir Analogue Source 8 6th November 2007 08:38 AM
Turntable Recommendation for Solid Plinth Project hifileslie Analogue Source 6 12th March 2007 02:00 PM
Lightweight turntable plinth. Paul Dimaline Analogue Source 29 16th January 2006 05:32 PM
DIY Turntable plinth rookster Analogue Source 15 11th August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
