| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I am planning to build a new plinth for my turntable. I would like to know the best medium for the plinth. >> Wood. >> MDF. >> Granite. >> Combination. Please comment... Best regards, Bins. |
#2 |
wood.no comment needed. everything else sux
stew ☮ -"A sane man in an insane world appears insane." |
#3 |
Hi Stew,
I am planning to build a plinth which is composed of multiple layers of wood with a solid granite base. Something pretty similar to: dps turntable, der plattenspieler, dps 2, dps 3, Schroder No. 2 fw - Soundscape HiFi And Music Best regards, Bins. |
#4 |
bins, problem is the grnite I think. Anything denser than the platter can cause reflections back into the platter, and hence the stylus tip. The granite must be isolated from the platter as much as possible.
take care. PM me or email direct if we're the only two posting....
#5 |
Here's another vote for wood. VPI quit making acrylic HW-19 super armboards so when I switched away from the SME it was drilled for, I had to make my own.
Walnut was at hand and I like how all 3 of my arms sound on it. One day I might try other woods just to see but I keep getting older and more complacent
#6 |
Wood (solid) has high Q problems so it's hardly used in speakers for example.
MDF solves the above and is for all intended purposes non contributary. If you must use something from your list, glue layers of each one together so each one doesn,t ring and add something that shouldn,t br there. Better yet use thick acrylic and steel or brass glued together Regards David |
#7 |
#8 |
This might be interesting....
Solid wood for loudspeakers are not mainly for the high Q, rather for troublesome crossgrain joints, that might crack with varying humudity.....otherwise a lot of ppl would love to use real wood for cab's. Resonances can be fought in various ways...... On topic, though, - hardwoods do have a fairly high Q, and some ppl dampen it with leadshot channels. Some say that an MDF base kills tone.... Butcherblock design might lower some of the Q, - how about a layered base with thin lead sheets in between? Do we really want dampening?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#9 |
1. What about the idea of using several layers of wood with some thin layer of acrylic/something similar between them so that they will help to damp the vibrations ? 2. Which is the best material for making the isolation feet ? Best regards, Bins. |
#10 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| where can I have a custom made heatsink? | Stefanoo | Solid State | 47 | 26th January 2012 06:06 AM |
| A new plinth for an old turntable... | simeon_noir | Analogue Source | 8 | 6th November 2007 08:38 AM |
| Turntable Recommendation for Solid Plinth Project | hifileslie | Analogue Source | 6 | 12th March 2007 02:00 PM |
| Lightweight turntable plinth. | Paul Dimaline | Analogue Source | 29 | 16th January 2006 05:32 PM |
| DIY Turntable plinth | rookster | Analogue Source | 15 | 11th August 2003 10:27 PM |
