Old 1st December 2012, 02:47 PM   #31
AVWERK is offline AVWERK  United States
Djn
Very nice marble work!
Since granite/marble is very stable, your next project (should you decide to accept it Mr. phelps) would be an a platter and integrated base honed to float it on air.
I have made one out of aluminum and one out of marble would be even better.
Very original design there!
2 big thumbs up
David
Old 1st December 2012, 03:53 PM   #32
My Lenco plinth
Layers of Plywood,MDF,Glue,Lead shot
Old 4th December 2012, 02:12 PM   #33
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Wow!
Avincenty,
Very nice traditional plinth. Did you do anything with the Lenco top plate? Further pictures available?
stew -"A sane man in an insane world appears insane."
Old 4th December 2012, 02:27 PM   #34
Dimitris
dimkasta's Avatar
Really interesting thread. I am currently designing one out of layers of wenge
Old 4th December 2012, 11:27 PM   #35
djn is offline djn  United States
djn's Avatar
Originally Posted by Bernauer View Post
djn! Please give some details about how you lengthened the Infinity Black Widow Tonarm. I just bought one with the specific idea to lengthen it. I didn't think anyone else had tried it. I have access to some very high quality carbon fiber kite spars and carbon fishing rod blanks that look very similar to yours. Would be very excited to hear from you how you did it. One of my main questions is whether the factory carbon arm is glued or somehow screwed into the aluminum pivot mount?
Thanks in advance :-) !!!
I used carbon fiber kite spars like you have. What was left of the original aluminum wand left of the stub had an OD the exact same size as the ID on the carbon tube so it is a tight fit with no glue are screw needed. I made the headshell out of an aluminum bolt that I put in the drill press and shaped with an angle grinder.
Originally Posted by AVWERK View Post
Djn
2 big thumbs up
David
Thanks much David. floating a marble platter would be a sight to see. I'll have to think on that for a while.
My "Art" website http://home.comcast.net/~djnagle/site/
Old 5th December 2012, 01:17 AM   #36
Originally Posted by Nanook View Post
Avincenty,
I documented the build in the Lenco Heaven forum.
build link
Alfredo
Old 5th December 2012, 01:46 AM   #37
Default research
Hi all
Stumbled across this thread. Seems to have wandered a bit from the original post, but I thought I'd share a link to a page I found a while ago when I was considering tearing apart my HW-19 and building a new plinth that might mimic an Aries or HR-X.
plinths - Audio qualia
I haven't moved on it yet, and I can't say anything about the definitive nature of the data presented, but I thought it was interesting and have been hoping to apply it to a plinth for a VPI Super Platter and bearing that I managed to get my hands on a few years ago.
Kevin
Old 5th December 2012, 04:44 PM   #38
lausar is offline lausar  United States
Default Slate
Originally Posted by binspaul View Post
I am planning to build a new plinth for my turntable. I would like to know the best medium for the plinth.
>> Wood.
>> MDF.
>> Granite.
>> Combination.
Please comment...
Best regards,
Bins.
I'm using Slate now but I'm going to try this cutting board.
Old 5th December 2012, 07:32 PM   #39
Nanook's Avatar
Default But why?
Isn't slate the Holy Frail for idlers? As I understand it ,the TD124 is a belt/idler hybrid. Regarding the use of a cutting board, I think that it looks like one that is very suitable for a plinth. I think it will look quite good. It's just the cost compared to using Baltic Birch ply (if easily available). I suppose if you can afford slate, then you can afford whatever you wish ; . At least there would be no issues finishing it as the melamine surface looks very good.
The use of cutting boards as plinths works because many are of suitable materials, and look good as purchased. They need no extra work to [put a finish on them either.The one pictured seems to be surfaced with melamine or similar. Be patient drilling into the melamine, use an awl or small pointed machinist's punch to start the centre of a drill hole and then a small bit. Once a small hole is established go to your final size. And support the backside of the cutting board to avoid any tear outs. The use of a drill press is pretty much a given, but if not put the cutting board on a piece of scrap.
Old 10th December 2012, 12:44 PM   #40
chopping boards made of slatted bamboo are very good. I use one under my Lenco, and I'm working on a plinth that uses flooring strips, also made of slatted bamboo, with cork and a damping compound I've developed. I'll post pics and measurements when I have finalised the design.
where can I have a custom made heatsink? Stefanoo Solid State 47 26th January 2012 06:06 AM
A new plinth for an old turntable... simeon_noir Analogue Source 8 6th November 2007 08:38 AM
Turntable Recommendation for Solid Plinth Project hifileslie Analogue Source 6 12th March 2007 02:00 PM
Lightweight turntable plinth. Paul Dimaline Analogue Source 29 16th January 2006 05:32 PM
DIY Turntable plinth rookster Analogue Source 15 11th August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
