| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I was idle this morning looking at converging several ideas to attept to come up with a precision RIAA stage - duinno if anyone else has mucked about with RIAA before? - I'd prefer to remove the op amps and have an all transistor stage.
Hum likes to have a nice "Noise to Signal" ratio ![]() To "Hum" is to be noticed Quality hum is when it pours out of Electrostatic speakers
#2 |
Have done a noise sim on this circuit? I think it will be quite noisey.
Q9 to Q12 and the associated resistors all add noise. Sor SOTA see Syn08's stuff in the analog front end forum - you should get some good ideas. If you are looking for a basic mag input RIAA, I'd suggest an op-amp based design. |
#3 | |
Op amps like L1037 are low noise optimized for mag inputs while LT1028 for MC's. Depending on topology you can even run them class A with buffers.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
The LT1115 has a nice one on the front page of it's data sheet.
#5 | |
You're right of course, but you obviously havent read my sig It's not bad at the moment - 2mV signal in to 550mV out - noise of course will be a function of gain also and there is the performance of those two op-amps anyway, with all of that gain in there it doesnt have much choice but to have some noise - I am just doing this as an idle exercise for fun. I'd like to know if it is possible that the better transistors made today could actually offer more design choices? Yeah I was just idling trying to figure out how a discrete transistor only RIAA with the proper corrections would look - getting the envelope shape right is a challenge.
#6 |
. . . you should go with infinia's advice on this one.
#7 |
diyAudio Chief Moderator
Moved to analogue source where all the Riaa people commonly visit.
#8 |
#9 | |
G² |
#10 |
| Solid Solid State Power Amplifier | PMA | Solid State | 265 | 30th August 2011 08:04 PM |
| Solid State | Voco | Solid State | 1 | 24th October 2004 09:05 PM |
| The Solid State Wiki - Your solid state reference guide | Jason | Solid State | 0 | 25th June 2002 05:26 PM |
| Page generated in 0.11870 seconds (80.37% PHP - 19.63% MySQL) with 11 queries |
