| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Unfortunately I haven't a picture from this neon lamp, because it was already remoooved.
This neon lamp is inside in the tubus (left side of the attached photo) of follow record player: MICRO ƒŒƒR[ƒhƒvƒŒƒCƒ„[SOLID-5‚Žd—l ƒ}ƒCƒNƒ‹@ The manufacturer of this neon lamp was Elevam: Welcome to Miyata Elevam Inc. Unfortunately it was not an article from the standart range. It was a custom made version for Micro. Perhaps in Japan such lamps are still available. Not helpful are normally used neon lamps in turntables like the photo number 3 and 2. The greatest similarity I note to the both last pictures from attachement - found by a great overview of such lamps Glimmlampen fr Signal- und Beleuchtungszwecke Last edited by tiefbassuebertr; 18th March 2010 at 01:53 PM. |
#2 |
I have forget the mentioned pics
#3 |
no Informations about this oversized neon lamp ?
The model DD5 (DD 5) uses also that lamp. BTW - how many commonly additional keywords there are in english for such lamp for strobe applications in turntables/record-players? |
#4 |
"turntable neon strobe lamp" might be worth googling..
You might try Koji at EIFL and see if he can help you source the required lamp in Japan.. EIFL: EIFL EXPORT HOME PAGE,vacuum tube,valve,amplifier,speaker,mail-order sales
www.kta-hifi.net |
#5 | |
typical sizes of standart neon bulbs for strobe applications by record player/turntable are very easy to find and looks like that: Specs for Neon lamp/Neon Lamp - JIANGSU BRIGHT GROUP and ELEVAM corporation -Neon Lamp- But not for the wanted oversized version from Elevam. I have now find out additional news: The Elevam model number of the wanted strobe light neon tube is follow: NL-72 (NL72, have a look to the attached PDF file) also used in the Technics turntable SL-1300 (SL1300) - maybe part No part No "SFDNNL78WM", but not sure in the moment. about the URL http://www.electricstuff.co.uk/neonlamp.html there are showed more very special neon strope lights BTW - the record player from Micro Seiki mentioned by post #1 is not the model 5. The right type number is "Solid Five" (Solid5, Solid 5) Last edited by tiefbassuebertr; 16th July 2010 at 09:58 PM. |
#6 |
Are there more terms in colloquial English (and also other languages like Spain, French, Russian or Italian) for the keywords "Neon Lamp", "Strobe Lamp" and "Neon Bulb" (for record player/turntable speed checking) ??
If I know the other terms therefore, I will try to find more about "Google" - Thank you for posting this informations. |
#7 |
I'm looking for the same neon lamp for my Technics SL200 MKI (first generation). The MKII and above do not carry the same lamp.
I've enclosed a picture of the mentioned lamp and 2 pages of the service manual for my turntable. Look at page 7 and 8 you'll find an exploded view of the unit with corresponding part numbers at page 8. You'll see that the lamp comes has a one unit glued within it's shade/holder (item 6) and then comes what they call the holder (item 6-2). Which in my opinion is more like a decorative very thin aluminum shell cover than an holder. To be able to get a picture of my lamp I had to cut open the white plastic holder which it was glued into it, then I manage to pull out the lamp. So, after getting a negative anwser from Union Electronic Distributors from the state I turned to eBay with no luck either. I send an e-mail to EIFL in Japan after finding your post, they will probably get back to me this week. As a last option we might need to purchase a complet used unit from eBay fro parts purposes only. Hope not to get to this point... Anyway I'll keep you posted on the outcome and please do the same. Thanks, Robert |
#8 |
Thank you for your advices and the attached PDF exploded view. The term here is "Strobo Illuminator" and the order code is "SFUM120-01A"
The manufacturer of the obsolete "NL-72" Welcome to Miyata Elevam Inc. is still exist. Unfortunately I don't speak the japanese language (English is not popular in Japan). Perhaps a member from Japan can find out there for us (maybe by phone), which company has overtaken the manufacturing of this oversized neon lamps. Many users are happy about this information. |
#9 |
any news?
#10 |
this same bulb is used in the Yamaha yp-800- I am looking for a source as well!
| Micro Seiki Tonearm. | MiiB | Analogue Source | 2 | 28th May 2007 03:14 PM |
| Another Micro Seiki restored! | Cobra2 | Analogue Source | 1 | 1st October 2005 10:06 AM |
| Micro-seiki DQX-500 | gotster | Analogue Source | 0 | 11th January 2005 07:44 PM |
| Micro Seiki 1500 | Cobra2 | Analogue Source | 18 | 15th November 2003 09:33 PM |
| Micro Seiki MC | ktigerb | Analogue Source | 0 | 27th May 2003 09:16 AM |
| Page generated in 0.13069 seconds (80.41% PHP - 19.59% MySQL) with 11 queries |
